Old 12-29-2008, 10:24 PM   #1
Shaffer4
Strange Cousin From The West..
Bad Hub(s)?
My truck's front axle (D44) stopped engaging today in either high or low range. The drive shaft spins, but it is putting nothing to the ground at either wheel in gravel, nadda. It is supposed to be a Detroit Locker in the front (and rear, according to the P/O) and all tires were spinning when in 4-wheel previous to this. There is no noise or grinding and I can feel the Transfer case hitting the detents when engaging it. It has Warn Locking Hubs.
We were using it today to move a non running car around our yard, it was working fine until we were trying to "Parallel Pull" the car over the curb (chain from my front hooks, across to the front frame of the car and pull it along side the truck). I had put it into 4 low to drive up into the slush beside the car and it was working then. But once we got to pulling the car forward (was working and would have if the 4WD stayed working... as odd as it sounds) the front stopped turning and I didn't hear or feel anything break free.
Being fairly inexperienced I bring forth my Delema to the 4 Wheeling Gods.
Shaffer4 is offline   Reply With Quote
Old 12-30-2008, 12:48 AM   #2
Mudder
Mudder's Avatar
Re: Bad Hub(s)?
Could be the hubs. The need a lot of attention lubbed and cleaned to work right.
Mudder is offline   Reply With Quote
Old 12-30-2008, 04:48 AM   #3
partyncwby
partyncwby's Avatar
Re: Bad Hub(s)?
Kinda seems weird that both hubs would pop at once. If one hub went, the other would continue to pull because of the detroit. I'm wondering if the P/O put locktite on the ring gear bolts when the detroit was installed. If enough of them backed out he may have not been able to hear the last two shear. Had the same thing happen to me. P/O put a detroit in my rear D44 in my CJ, no locktite. Sheared three bolts and after I pulled the carrier I was able to spin the broken bolts out with my finger. I'd pull the cover and have a look-see.
'68 K20
'71 C20
'79 K20
'77 CJ 7
'89 XJ jacked and beat
'93 F250 (it's only ford on the outside)
partyncwby is offline   Reply With Quote
Old 05-23-2009, 08:06 PM   #4
Shaffer4
Re: Bad Hub(s)?
Finally(!) got around to taking a closer look at this issue. Pulled the front cover and everything looks fine... better than fine, like brand new. everything spins right with the hubs unlocked, but only the passenger side engages with both hubs locked.
So I assume this means that the driver's side hub is caput. On another note, how much play should there be in the hub itself? the passenger side hub has some slop before the axle begins to move.
Old 05-23-2009, 09:13 PM   #5
Shaffer4
Re: Bad Hub(s)?
Well.. its not the hub... not exactly...
I think I brokeded it.
Old 05-23-2009, 09:58 PM   #6
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Bad Hub(s)?
You did a great job brokededed it! GO WARN HUBS! The UNBREAKABLE HUB. I think you might need, just thinking here, a new axle there. At least thats the cheaper side.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 05-23-2009, 10:12 PM   #7
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: Bad Hub(s)?
wow... both sides? good job buildin that engine...
Eturnit3 is offline   Reply With Quote
Old 05-24-2009, 12:40 AM   #8
Shaffer4
Re: Bad Hub(s)?
I think it was mostly broken before I bought it. I was really hoping I wouldn't have to dig too deep into the axle ($ is tight), but that appears not to be the case.
Old 05-24-2009, 01:08 AM   #9
Shaffer4
Re: Bad Hub(s)?
actually, I think it is a fairly stock 350 in it and I've barely even driven the thing; 70 miles at most. So far it is just the one side; though the passenger side hub seems kind of sloppy, there is a bit of play 1/4ish" of rotation before the axle starts to spin.
Old 05-24-2009, 02:32 AM   #10
Shaffer4
Re: Bad Hub(s)?
so, anyone know of any good tear down articles?
Wish I were a rich man, because golly those ORD pieces look nice....
Old 05-24-2009, 03:19 AM   #11
Shaffer4
Re: Bad Hub(s)?
got the end of the stub shaft out of the hub, the hub still looks like new... the stub shaft twisted off right were the splines end... the amount of twistage makes me wonder what the rest of the axle shafts look like...
Old 05-24-2009, 04:02 AM   #12
Shaffer4
Re: Bad Hub(s)?
Okay, Okay, last one, I swear... OCD + Digital Camera = well... I wasn't ever really good at math...
you weren't lying about those Warn hubs... you can see the second row of cracks, they start just above the mesh marks where the hub splines rode.
Old 05-24-2009, 08:50 AM   #13
LONGHAIR
Re: Bad Hub(s)?
That right there is exactly why I always caution people against putting a Detroit Locker in the front of anything. It's not the only reason, but it is a good one. Some slippage somewhere in the drivetrain relieves the strain. Most of the weight of a pick-up truck is right over the front wheels. It puts a lot of pressure on the axles. Bigger tires and more horsepower make it worse.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-24-2009, 06:06 PM   #14
Shaffer4
Re: Bad Hub(s)?
Pulled the passenger side out of curiosity, everything seems to be intact, but it is pretty hammered...
dunno if the stub is supposed to be that sloppy and the splines are pretty worn but the look of it and also by the look of things in this next pic.
This Hub has taken a bit of damage, which most likely explains the hub slop on this side...
So I'll probably need to do both sides to be safe.
Thread Tools
Display Modes
