Old 12-30-2008, 10:26 PM   #1
JAKES 68GMC
Aluminum slot wheels rule...
Easiest way to get 2-3" of lift
I want to put a small lift on my GMC, 2-3 inches just to give it alittle more authority. Whats the easiest/cheapest way to do this? Add-a-leafs or rearched springs? I'd like to stay away from lift blocks, as my rear end already wheelhops bad enough when it spins posi. Thanks for the help guys.
JAKES 68GMC is offline   Reply With Quote
Old 12-31-2008, 04:03 AM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Easiest way to get 2-3" of lift
add a leaf is what i did to gain a little more to clear my tires i also added in a wedge block to make sure my driveshafts matched up fine
cant remember what i spent.. but also
add a leafs might stiffen your ride a little bit and adds to towing capacity...taller sidewall tires? as long s they arent too ridiculous
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 12-31-2008, 04:25 AM   #3
BurnoutNova
BurnoutNova's Avatar
I wanted to get a 2.5" rough country ez ride kit for my 71 K10. 2.5" blocks are ok with me. I was just recemtly looking at thier site tho and could only find 4" kits. I might have to get my springs re-arched and just by some blocks.
I've also heard you stand a risk of the springs cracking when the're heated for the re-arching process. I'm not sure I want to take the chance paying someone to ruin my springs.
BurnoutNova is offline   Reply With Quote
Old 12-31-2008, 09:33 AM   #4
I`d arch the springs.I never use heat and neither does a spring shop.They ose a roller press and I use a BFH and anvil.You take a pack apart,on the main leaf you pound from center-out in both directions staying near the mounting area/center,match the other leafs to the main,then match the other side main to the first one,and repeat matching lesserleafs.A spring shop will want a couple hundred per axle and will add a long leaf,most likely.
Old 12-31-2008, 12:55 PM   #5
CPNEJR
CPNEJR's Avatar
i'd have a spring shop re-arch the springs for me unless you want to try it yourself the way Special-K described it.
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 12-31-2008, 06:47 PM   #6
BurnoutNova
[QUOTE=special-K;3057282]I never use heat and neither does a spring shop.QUOTE]
I thought they used heat? Anyway I've heard they can break once thier re-arched. Maybe it was just a horror story that rearely comes true,
Old 01-01-2009, 10:53 PM   #7
Well,old fatigued springs can brake.I`m sure if a spring that`s seen better days was re-arched it might break easier.I`ve seen springs break that were original.
Usually what you`ll hear is the`ll just settle back down.I never have that problem.Any freshly arched spring can settle,new or old.
Old 01-02-2009, 12:16 AM   #8
JAKES 68GMC
Ok, I'll probably get them rearched and have an extra leaf thrown in to help keep their arch. And my springs now are pretty soft. Thanks for the help guys.
Old 01-02-2009, 09:14 AM   #9
Sounds good.Let us know how it turns out.I still need some altitude on my white truck.
Don`t be a stanger.Heck,we have a couple young guns that need a good example to follow.
Old 01-03-2009, 09:52 AM   #10
CUSTOM/10
CUSTOM/10's Avatar
Jake
You have a PM.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 01-03-2009, 09:57 AM   #11
msgross
msgross's Avatar
THis short add-a-leaf gave me 1.5" and more stiffness on my K-10. You could do it and a zero rate leaf from ORD or DIY... You might need new U-bolts though.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-03-2009, 10:24 AM   #12
FormerMember
You should get new ubolts every time. They are stretch to yield hardware.
FormerMember is offline   Reply With Quote
Old 01-04-2009, 06:43 PM   #13
JAKES 68GMC
I try not to be a stranger, Tim. But sometimes I just get so busy I can't find time to bring my 2 cents to the board. But I try to come around and post more then i was.
Old 01-04-2009, 07:37 PM   #14
As long as you`re too busy.That`s a good excuse.
Thread Tools
Display Modes
