Old 01-02-2009, 10:33 PM   #1
stevek20
'67 to '72 cab on '73-'87 frame questions
Has anyone done this before? I have a 1975 K20, would like to shorten and put an earlier '67-'72 style body on it. I was wondering if anyone knows if the cab mounts will line up or at least be fairly easy to modify to work. Just to explain, I am confident enough to cut, weld, fabricate etc. if necessary but was curious just how close they were to lining up. I know, if its too much work I'd be better off getting the earlier frame and everything, its just that I already have a good donor '75 k-20. Any help would be much appreciated. Also- tried searching but does anyone know if the 1/2 ton frames are the same metal thickness as 3/4 ton frames, or are the 3/4 ton frames heavier steel? thanks
stevek20 is offline   Reply With Quote
Old 01-02-2009, 10:49 PM   #2
ChaseDale3and8
ChaseDale3and8's Avatar
Re: '67 to '72 cab on '73-'87 frame questions
Send a PM to a member here called Mudder. He has done it, has the pics, and a great description on how to do it. I do know that the 73-87 wheelbase is longer than the 67-72, so it would have to be cut down some. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 01-03-2009, 04:36 AM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I have done this before, but it would be easier to cut the rivets on the 2wd frame on the cab and bed supports to bolt to the newer frame. If that isn't help, like above, try Mudder, he has a good explanation on the conversion. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Thread Tools
Display Modes
