01-06-2009, 07:21 PM | #1 |
rear brake locking 14 bolt diff
i have a 1972 chevy blazer-i did a axle swap military axles dana 60 in front and 14 bolt diff in rear. the brake booster and prop valve is the stock one, why is my rear diff locking on me and i press on the brake hard??
01-06-2009, 07:36 PM | #2 |
Re: rear brake locking 14 bolt diff
01-06-2009, 08:06 PM | #3 |
Not enough weight in the back.
if you went to 13" drums, you might try the anti skid valve from the back of a squarebody truck. it has a little flapppy arm to the rear axle you will need to reengineer.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
01-06-2009, 08:09 PM | #4 |
ok i seen that before.what about i use a adjusteble valve
01-06-2009, 08:36 PM | #5 | ||
That valve is supposed to "self adjust" the brakes to put more braking power to the rear when it is loaded. It works by variations is ride height...as the rear squats down you get more brake, thus taking away braking when empty. This truck looks like it has air bags....this would get really tricky trying to make it work with that much travel.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
01-06-2009, 08:36 PM | #6 |
what about if change to rear disc?
01-06-2009, 11:16 PM | #7 |
Rear disk is nice, you loose a lot of weight,but it still might lock before the front. Ither way you could just ad an adjustable porportioning valve to the rear brakes, and then adjust as needed. If yo go to disk, unless you use the caddy calipers( or some expencive aftermarkets) you will loose your ebrake
Thread Tools | |
Display Modes | |
