Old 01-08-2009, 10:18 AM   #1
87Bob
Cruise Control Intermitent Wipers(Factory)Tilt
I have a tilt column that I am planning to put into my 85.
The truck has no cruise and no intermitent wipers.
The tilt column has the cruise and delayed wiper signal lever. But no interval wiper module.
Does anyone have a photo of the wiper module inplace on the column?
Does anyone have some underhood photos of a factory cruise set up? If you have parts availible see the WTB section.
Thanks!
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 01-11-2009, 12:17 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Cruise Control Intermitent Wipers(Factory)Tilt
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-11-2009, 12:46 PM   #3
87Bob
Thanks for the bump.
Old 01-11-2009, 10:10 PM   #4
86 silverado short
I would also like to see this set up. If anyone could help please.
86 silverado short is offline   Reply With Quote
Old 10-22-2009, 05:22 PM   #5
joe231
joe231's Avatar
back from the dead.......
CHEVY ONLY
Old 10-22-2009, 09:30 PM   #6
menace121978
menace121978's Avatar
not whats wanted but thought i'd share anyways... i happened to score an intermitent wiper switch for the dash today at pick n pull. there was a cherry 85 stepper w/ what looked to be 117k miles. was a clunker turn in. very sad day seeing all those trucks with pink painted on the engines and parts RIPPED off. even seen a 454 in a 90's burb with 60k painted pink and a 99 ls5.3 in an ecsb truck. unbelievable.... anyways back on topic!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 10-23-2009, 07:32 AM   #7
Keith Seymore
Keith Seymore's Avatar
Thanks!
Here's the wiper module, at home under the column:
I also have cruise, which I installed from a service kit, but it's on a V6. Let me know if you'd like some pictures (I don't have any underhood shots handy).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-23-2009, 10:16 AM   #8
joe231
joe231's Avatar
I picked up the older dash mounted switch and module from my local pull-a-part for dirt cheap.....but it doesn't work
the P.O. had swapped in a newer tilt column with wipers and cruise on the turn stalk....so now I'm going to convert to use it
K
nice pic Keith....
I would like to see the cruise set-up if you don't mind snapping some pics
CHEVY ONLY
Old 10-26-2009, 07:49 AM   #9
Keith Seymore
Ok - here's some cruise pics (disregard the dirty engine compartment, please).
As I mentioned, I added cruise to my truck as a service kit. It came with that vaccum diaphram, the mounting bracket, the fittings (on the throttle lever) and the necessary linkages. (It also came with the cruise stalk and necessary modules, switches and wiring).
Hope that helps, let me know if you have any followup questions.
K
1979-1986
1986 - 2019
Thread Tools
Display Modes
