Old 01-12-2009, 02:29 PM   #1
AJs72K5
AJs72K5's Avatar
Hayden Transmission Cooler
New, unused Hayden transmission cooler (will also work as an oil or power steering cooler). Model OC-1403. Everything that came with it is included. I opened the box to look at it, and decided to go a different direction. Located in zip 78231. $30 shipped to the lower 48 states.
Thanks!
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 01-12-2009, 05:13 PM   #2
Slik69
Re: Hayden Transmission Cooler
This mounts to the radiator correct. Are these afficient in cooling. What did you go with.
Slik69 is offline   Reply With Quote
Old 01-12-2009, 10:09 PM   #3
AJs72K5
AJs72K5's Avatar
Yes, these mount to the radiator. Fairly standard setup for an tranny/oil cooler. I fabbed up some brackets and went with an overall bigger one that has tabs on it.
- AJ
Old 01-14-2009, 08:30 PM   #4
AJs72K5
AJs72K5's Avatar
ttt.
- AJ
Thread Tools
Display Modes
