Old 01-13-2009, 11:04 AM   #1
cochino12
It followed me home?
cochino12's Avatar
New hd truck bs compared to ours
I found a set of 18" rims for my crew cab that came off a newer Hd truck (stock 4wd) and wondered if they would fit my 2wd truck? I know the stock hd rims work fine but the new rims are 8.5 wide and the stock are only 6.5". The owner is going to measure them but thought I would check here too.
The tires on the truck now are pretty much dry rot and unsafe so I figured I'd buy a set of used tires and run them for now since I have to get the truck roadworthy by 3/1. Here are the wheels I found for $300
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-13-2009, 11:31 AM   #2
SmokeShow
SmokeShow's Avatar
Re: New hd truck bs compared to ours
If those are the 18" 8 lug Eagle 114's they are 9.5" wide and have right at 6" of backspace. If new stock wheels fit these older trucks fine, then I would think these will too. I'm not sure what may be of concern.
These also won't stick out of the fenderwell much, if any.
I had a set on my 02 Chevy. If you don't want them. Let me know where they are for $300. I'd like another set.
02 Chevy 2500HD D/A EC SB 4x4
MA SCIII trans, EFI Live, 5" exhaust, 5% tint...
83 GMC K30 Crew Cab Short Bed
06 Duramax & ZF6 (to be installed) and more to come...
SmokeShow is offline   Reply With Quote
Old 01-13-2009, 11:59 AM   #3
cochino12
cochino12's Avatar
I guess my concern is the newer stock wheel fitting only because it's 6.5" wide, these are 2" wider and are going on a lowered 2wd. I think if they are are 6" bs they arent going to work, I think these trucks (2wd at least) need 5 or less
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-13-2009, 09:53 PM   #4
SmokeShow
SmokeShow's Avatar
so where they at for that price then?
Old 01-13-2009, 10:08 PM   #5
87c10slammer
truck addict
they will fit inside the fenders and not rub... they are tucking insode the fenders more but the rim is alot larger then the stock one so it wont have any control arm clearance issues... i would but them if i had 8 lug axles...
87c10slammer is offline   Reply With Quote
Old 01-13-2009, 10:22 PM   #6
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
I hope they will work for you, Should look Sweet on your Shorty Crew Project..........
I Can't decide whether to stay with Rally's or Put on a Set of Cragars i have for Mine.....
Good Luck, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 01-15-2009, 11:36 AM   #7
cochino12
cochino12's Avatar
Good Luck, Rick
I hope so, I'm going to pick them up today or tomorrow.
I think you should stick with the rally's and send me the cragars ha ha.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-16-2009, 04:56 PM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
This is a different thread than what I thought
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-16-2009, 05:19 PM   #9
SmokeShow
SmokeShow's Avatar
guess you weren't thinking about "backspace" huh??? That's funny.
Thread Tools
Display Modes
