Old 01-14-2009, 11:54 AM   #1
justpball
justpball's Avatar
backfiring question
last night I ran low on fuel and now my burb will crank and idol just fine but as soon as you give it gas it spits and sputters and dies. i thought I might have sucked a bunch of trash into the fuel filter so I changed that but it didnt help, the truck has been sitting for a few years so i dont know what it could be.
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 01-14-2009, 03:35 PM   #2
screwballl
Tonawanda 454
screwballl's Avatar
Re: backfiring question
sounds like it may be time to drop the gas tank and get the inside cleaned out... this southern humidity creeps into every tiny crevasse and can slowly rust it from inside out. The intank fuel pump may have the filter piece dried out or clogged, or the low fuel caused the pump to burn out. Mine stumbled a little bit but that was fixed when I replaced the pump.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 01-14-2009, 05:07 PM   #3
justpball
justpball's Avatar
thanks bro, i was thinking the same. just wanted to see if anyone else had any other ideas...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-14-2009, 08:07 PM   #4
screwballl
Tonawanda 454
screwballl's Avatar
I am sure those with more technical experience should chime in here any time with more ideas...
Old 01-21-2009, 04:39 PM   #5
justpball
justpball's Avatar
coil went out!
87 Crew SWB
Build for the crew
90 burb 2wd
Thread Tools
Display Modes
