I have had these for several years now and my truck is still far from ready for them. I don't want to sell but economy forces my hand. Not sure how old they really are, anyway the box was in pretty bad shape so I tossed it back when I got them. I didn't think I would ever sell them to be honest. I think it was from late 70s early 80s but the headers are still perfect and have never been mounted. Box said fits 68-72 chevy truck/blazer 4X4. I would like $350 shipped I believe this is a fair price for something this rare if you guys disagree please PM me your thoughts, don't flame me. If consensus says I'm way off I will re-evaluate.
2807 is stamped in the flange. ***UPDATED*** called Hooker these are 30 year old headers last cataloged in 1977 67-72 Chevy/GMC 4 wheel drive 1/2, 3/4 and 1 ton truck, Suburban and Blazer fits AT and manual (not manual colom shift) Pictures ![]() ![]() ![]() ![]() ![]() ![]() Thanks, James
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 Last edited by teamradrz1; 01-16-2009 at 03:48 PM. Reason: Lowered price |
Re: Rare NOS Hooker supercomp Headers
I would suggest pictures. You will get interest, but no takers on a 400.00 set of headers without some quality pictures to show people what they are buying. Are they coated at all? This is just a suggestion.
Shawn Also. Be careful throwing the word 'RARE' out around here. That word is the cause of more controversy. Maybe use the word limited production. ![]()
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 01-15-2009 at 03:26 PM. |
#3 | |
They are not ceramic coated they have a silver finish to them. Again though I am more than willing to hear what people have to say and maybe I'm completely wrong. I've tried to look up the part # with no luck if someone else knows how to look that up that would be awesome.
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 Last edited by teamradrz1; 01-16-2009 at 01:28 AM. |
![]() Join Date: Feb 2001
Also BB or SB motor?
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 |
Not the exact number but looks like the closest application??
Super Comp Full Length – 2WD Truck Super Comp. Header Part #: 2808HKR UPC #: 700414008707 Hooker has long been known for its dominance of the drag racing circuit, but did you know that Hooker can help the off–road enthusiast scorch the deserts, mountains and swamps of the world? Hooker Headers use long tube lengths and long transition Collectors to produce monstrous lowmid range torque without sacrificing top end horsepower. Each Hooker header is designed to provide the finest fit and most durable construction available on the market today. Hooker offers a complete line of full length and emission compatible Headers for the off–road enthusiast to choose from. Whether it be a rock crawling Jeep or a 1000 mile desert racer, Hooker can bring your performance expectations to a new level. 68–87 Chevy/GMC 1/2, 3/4 & 1–Ton Truck, 69–91 Blazer/Yukon/Jimmy/Suburban/1–Ton Crew Cab: 265–400, Full Length Tube Size 1.625" x 30", Collector Size 2.5", Collector Length 8", Port Shape: Same As Port, Black High Temp Paint Installation Notes Breaking in an engine with ceramic coated Headers WILL result in damage to the coating and will VOID all warranties. Ceramic coated Headers require several heat cycles to fully cure before they will withstand extreme heat. Hooker recommends using cast iron exhaust Manifolds or old Headers to break in new engines to avoid coating damage. Please call Hooker tech service at 270–781–9741 for additional information regarding ceramic coated exhaust products. Features Tuned-length primary tubes for maximum exhaust scavenging and velocity Mandrel-bent tubing for smooth exhaust flow Light weight & sturdy 18 gauge tubing Long transition collector for decreased back pressure 5/16” machined flanges for a perfect seal Industry’s best welds for durability Designed for optimal performance All necessary hardware included for a complete installation Last edited by 70rs/ss; 01-15-2009 at 05:17 PM. |
OK so check this out I called Hooker Headers to look up the part # as I couldn't find anything. took 20 mins for him to find the part # he had to go all the way back to 1977 catalog to find the part # and it fits as follows.
67-72 Chevy/GMC 1/2, 3/4 ton 4X4 AT or Manual (will not fit manual colom shift) so I think this may be concidered rare as NOS from 1977 thoughts?
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 Last edited by teamradrz1; 01-15-2009 at 06:26 PM. |
67-72 Addict!
Your headers are probably about 20 years old with the nickle silver finish. I run the 2808 on mine and they fit great but the finish flaked off after awhile. Here is a set that ended 4 days ago on ebay that I was watching.
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123 The item number was 120359095687
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 01-15-2009 at 06:34 PM. |
The other thing I noticed is all the newer Hooker Headers they are all for 2 wheel drive did not see any 4X4 headers. which limits the market but would think makes these harder to find.
Like a Rock!
Jegs sells 4x4 headers from Hooker. Do yours look like these?
http://www.jegs.com/i/Hooker/520/2453/10002/-1
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
#11 | |
Have you ever held them in place to see how low they hang?
#13 |
well I have some headers on it now headmen I think (cheap) ones and these are definately shortertop to bottom.
the right side dimentions height is 16" highest to lowest point. length is 29"
#14 |
#15 | |
Like a Rock!
#16 |
Moderator
![]() Join Date: May 2007
#17 |
New supercomp headers without coating start at around $450 link http://store.summitracing.com/partde...5&autoview=sku I thought $400 for NOS that have some sweet bends to them would be a good place to start and I also said if you thought differently to PM me. I'm not sure what they are worth to be honest I paid $350 for them 8 years ago. And this is not an auction format I'm open to offers as well. But at $400 they are still cheaper than the new ones and these were made specifically for our year trucks not 67-87 like most headers are.
#18 |
Designated A-hole!
Not only is that correct, it is also enforced.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#19 |
67-72 Addict!
I'm assuming the part number for 4x4 is 2807 compared my 2808 for 2 wheel drive. If that is the only difference, somebody will be getting headers that clear the frame, starter, etc. Another thing is plug access is easy and so are the bolts
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#20 |
Bump for lowered price
Thread Tools | |
Display Modes | |
