05-14-2002, 02:16 AM | #1 |
recent purchase/Drivetrain swap
I have just purchased a 1969 GMC 910 Custom, it has an inline 6 and 2 speed powerglde tranny. I already have a thm400 and was wondering what kind of problems guys have ran into swaping out the old power train for the new one. I plan on putting a 383 stroker into this truck with the aforementioned trans. I also want to swap the front end over for disc brakes and change the rear end to handle the HP as well as converting over to 5 lug wheels. Any suggestions at all would be helpful as this is my first project. Thanks, Great forum too!!!!
05-14-2002, 06:40 AM | #2 |
The turbo 400 is longer than the powerglide and will require a shorter driveshaft as well as a different output shaft yoke. I would mount the V8 on the 6 cylinder frame mounts as it gets the weight further back for better handling and increased rear wheel traction. You might have troubles running a large cap HEI however. If you get a TH350 and use the 6 cylinder mounts you can keep your existing driveshaft.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
05-14-2002, 07:12 AM | #3 |
I have mine set up on 6/250 stands,& the HEI is tight but does fit. What I like to do is drill the eng mount holes in the stands to 5/8",& slot the trans crossmember holes. This gives a little adjustment......not a lot,but just enough for the HEI. If you already have a good 400T,I would use it,the placement of the crossmember will be different,& as posted it will be a little longer(about 11/16"for the short tail),than a 350T. It is pretty cheap to shorten & balance a shaft,or you can go to a 1 pc shaft(4" diameter in the 6' lenght range). Up front,I used the 73 up long waterpump & accessories to put the fan in proper location with the radiator. In the ex department,with an auto trans.......pretty much anything goes. I have a set of 2452 Hooker comps,& good ground clearance.......or you can run the straight dump 2 1/2" Vette ram horns (in 6 cyl position ). Good luck.....69longhorn.
http://community.webshots.com/user/hotrodhorn |
05-14-2002, 11:19 AM | #4 |
Thanks for the info guys. Any other sugestions anyone may have would be greatly appreciated.
Thread Tools | |
Display Modes | |
