Old 01-26-2009, 08:28 PM   #1
RED69K5
bumper straightening
Is there such thing as a place that can straighten bumpers?
I have the original dealer installed rear bumper for my '62. It has the dealer's name and city engraved in it. The bad thing is, its pushed in on one side. I would like to straighten it and put it back on the truck to keep the truck original.
Does anyone know of a place that can do this? Preferably near the Dallas / Ft Worth area.
RED69K5 is offline   Reply With Quote
Old 01-26-2009, 11:39 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: bumper straightening
how bad is it, I straightened mine a little bit with a 3 and 8 pound sledge, and a chunk of railroad track for an anvil...wore me out though
you should have some chrome/replating shops in your area (big city) they usually straighten before they replate.
Old 01-26-2009, 11:40 PM   #3
jonzcustomshop
1961 crewcab
also.. have you unbolted it from the truck yet? sometimes the bent braces are what is holding it in the bent shape.....
Old 01-27-2009, 11:01 AM   #4
RED69K5
It is off the truck. The left bracket is bent, but I think it can be re-fabricated pretty easily. The left side is pushed in about 4-6 inches, no creases though. I think if someone heated it up and put it in a press, they could straighten it back to normal.
Old 01-27-2009, 11:17 AM   #5
scotts62
One day...
scotts62's Avatar
Try and tie a rope to it and to something solid like a pole or something and use the truck to put tension on it the heat it up very little with a torch, take your time with it and it should come out a lot closer to where its suppost to be.
Scott
93 crew cab build
Project 62
Old 01-27-2009, 01:59 PM   #6
502tripower
502tripower's Avatar
If you look at the bumper on my truck you can see where I heated it up with a rose bud and then layed it out on a metal table and started hitting it with a sledge. It was bent up pretty bad. Once I got it fairly straight I clamped it to the table and stared working it using the rose bud and sledge. Before I started you would of thought it was unusable. I just needed a bumper to do my mock up and this was what I had so, I figured if it didn't work I wasn't out anything. It actually came out pretty darn good. Good Luck.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 01-27-2009, 02:40 PM   #7
scotts62
One day...
scotts62's Avatar
Yeah id say! It looks good!
Scott
93 crew cab build
Project 62
Old 01-27-2009, 08:36 PM   #8
mbgmike
They exist. Theirs an old man in south houston Texas that has a bumper hammer. He is real reasonable. You rear bumper is alot harder to straighten then a std bumper. Most of those are pretty thick steel and you probably would be better of like above. Use a torch and hammer
mbgmike is offline   Reply With Quote
Thread Tools
Display Modes
