Old 02-08-2009, 01:40 PM   #1
Prathbun
Prathbun's Avatar
Talking Shifter Handlle Question
I have a tilt column ('72) and I have added a Camaro style steering wheel. My shifter handle seems like its way out there. Is there any other options for a shorter shifter handle that would work? Thanks for the help.
It's Not Rust, It's Patina!!
1967 C 20 Large Window, 700R4, 283, Tilt, PS, PB.....A Rusty But Trusty Gas Hog
2008 Silverado LTZ 1500 4x4
Prathbun is offline   Reply With Quote
Old 02-08-2009, 04:08 PM   #2
66skylarkpost
66skylarkpost's Avatar
Re: Shifter Handlle Question
i'm not sure .i have a 4 spoke camaro as well in my 70, some years ago i installed a late 70's van tilt and it has a much nicer shorter arm , i'm not sure if they will work in an older column
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 02-08-2009, 06:13 PM   #3
magsnubby
magsnubby's Avatar
Could you shorten it up and rethread the end?
magsnubby is offline   Reply With Quote
Old 02-08-2009, 06:14 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Use a shifter from a van tilt. They are shorter, and work perfectly with a smaller steering wheel.
leddzepp is offline   Reply With Quote
Old 02-08-2009, 08:42 PM   #5
463
463's Avatar
you can use a gm car shifter from the 70's and mayby as late as a 1990 caprice car. use a punch and bump the pin up and pull the shift lever out. you may want to grab the spring also.
Trueman
463 is offline   Reply With Quote
Old 02-19-2009, 11:50 PM   #6
Prathbun
Prathbun's Avatar
Thanks for all the input. This is the type of lever I need. As you can see, this one is almost completely trashed!! I'm having a difficult time locating a van shifter (I think it would look best with my smaller camaro steering wheel). Will I'll need to go to a GM parts counter? Does anyone have any other suggestions??
Thanks for the help!!
Old 02-21-2009, 03:19 PM   #7
Prathbun
Prathbun's Avatar
ttt
Old 02-21-2009, 03:26 PM   #8
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Check out the Jeeps in the junkyard as well. They used alot of the same parts.
low'n slow is offline   Reply With Quote
Thread Tools
Display Modes
