02-10-2009, 04:20 PM | #1 |
Help with new vent window rubber
Need help with the new vent window seal I got from LMC. I have an 85
K10 and the old seal was 2 pieces with the back side having tangs to hold it to the vent rail. This one is one piece, has no tangs on the back side AND we're having trouble getting the rest of it to stay seated into the rail. It did'nt come with any instructions. Any hints or suggestions would be greatly appreciated. mike 85 K10 project |
02-10-2009, 06:25 PM | #2 |
Re: Help with new vent window rubber
You may have the wrong rubber kit, 73 to 80 are 2 piece, 81 up are 1 piece, has a po swapped out the vent window assemblies?
77 Cheyenne no longer in bits |
02-10-2009, 10:46 PM | #3 |
Born a Chevy Man
'85 Should be a one piece. He has a '85. It should have had a one piece when he took it out. The PO must have put in the wrong one (a two piece). Anyway, something is wrong.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) CHEVY, American made w/pride! If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
02-11-2009, 10:05 AM | #4 |
Thanks for reply, I don't know if it was replaced but the back rail does have the slots for the tabs to be pushed thru and bent over to lock in. I was working on passenger door 1st so I can take off the rubber on driver's door and see if it is different. So is that back rail just glued down?
Tia mike 85 k10 sb diesel |
02-11-2009, 11:18 AM | #5 |
Born a Chevy Man
I have never done this but sure you have to get the rivets to install the rubber. I would think LMC would have these and the punch to install the rivets.
05-18-2009, 01:10 PM | #6 |
My '87 has the two piece seal and I'm the original owner (never been changed out).
Do you suppose there was some difference between assembly plants? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-18-2009, 01:26 PM | #7 |
There must be because I have checked with po and this was original rubber. I feel sorry for anyone trying this job.
05-18-2009, 09:23 PM | #8 |
Crap, hate to hear that...my drivers side vent window makes an ungodly noise. If I could get it fixed, my truck would be relatively quiet. Is it body shop time?
05-19-2009, 09:48 AM | #9 |
When I installed that new rubber it was like it was too small. You get one part seated good and work your way around and the other end would be pulling out already. AND it still made noise after putting it in. Wish somebody could find a part for these vents that worked right besides sealing them shut.
Seagator |
05-19-2009, 11:34 AM | #10 |
I'll put new vent assemblies in before I put on the LMC rubbers again...
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
05-26-2009, 11:22 AM | #11 |
Thanks, guys. Got 'er done this weekend.
It wasn't too bad: I was able to replace the vent window without pulling the door glass. The hardest part was getting one of the phillips screws loose! I also replaced all the rubber on the driver's door. The LMC rubbers fit the vent window pretty well; it was a little tricky getting the rubber on the window track at the rear of the door and the attachments didn't quite line up with the slots in the door itself but not bad considering. By the way, my truck had the two piece setup on the driver's door and a one piece seal on the passenger door. I'm thinking the driver's side might have been changed out during the time my Father-in-law had the truck (and that the passenger side is original). K
06-17-2009, 08:46 PM | #12 |
I have an 84 GMC shortbed and I have bought the new window and vent seals from LMC for it. Also my vent seal is one peace. Do you guys know if you have to remove the pivet rivet and the vent window to remove the vent seal? It appears you do and I've never done such a thing so I'm not sure where to start. I know you can buy new rivets from LMC but I've read on here that you need a spiecal rivet tool.
06-17-2009, 08:55 PM | #13 |
I can't comment because I replaced the whole assembly (I didn't dissassemble the glass/pivot from the frame).
K
06-17-2009, 09:00 PM | #14 |
Thanks K for your replay. Okay so the 90-91 window vent assembly I see is the simpliest fix but ok i have dump question. Does this assembly come with the window vent (glass) and everything? I think i've already answer my question but i'm just asking.
06-17-2009, 09:01 PM | #15 |
To replace the seal you have to take the vent window apart and drill out the rivets, only drill out the pivot and the rivets holding the rear rubber, when you buy a rivet kit it should come with a punch.
06-17-2009, 09:04 PM | #16 |
Yup, comes as a complete unit.
07-08-2009, 12:22 AM | #17 |
My 84 GMC has two rubber pieces rubber one. I removed the pivot rivet by cutting the head/top off with my dremel tool. I started to grind the bottom of the rivet first but it was not working to well. Looked like I would damage the arm so I went for the top since there was enough room for the cut wheel to fit between the head and the arm. Anyway I got the vent window off the frame and noticed the rubber was two pieces instead of one. My looks like the LMC parts for a 73-80 instead of 81-87. LMC's or GM's fault, I don't know but I wished I never started this. Guess I'll have to call LMC and exchange them. In the first pic here the far right is the new single piece.
07-17-2009, 10:43 AM | #18 |
Where can I get the punch and pivot rivet? I have an '87 with 2 piece seals on both sides too.
I just got off the phone with LMC and they don't have a listing for the tool, just the rivet. Any other recommendations? Last edited by nlped; 07-17-2009 at 10:57 AM. |
07-17-2009, 11:07 AM | #19 |
Next project: 1970 K10
Keith - You say you removed the vent assembly without having to remove the door glass? Can you share any tips on doing that? My drivers wing leaks like sieve, and I have a good Suburban wing that I want to swap out.
nlped - LMC has the hinge rivet, p/n 30-0519. It seems to me I have heard people used regular pop rivets for the rubber-to-frame.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-17-2009, 11:09 AM | #20 |
Thanks glock35ipsc but I need to know where to get the actual tool used to "squash" these little ba#tards smoothly
07-17-2009, 11:19 AM | #21 |
www.cheyennepickup.com
Part number VT835, $5.00 Or you can make one out of a piece of 1/4" or 3/8" round bar and dremmel out a concave part in one end. You'll probably want some sort of buck to use on the back side too, such as a hammer or a thick piece of steel. Something for the rivets to back up against as you hit then with the rivet tool
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-17-2009 at 11:25 AM. |
07-17-2009, 11:25 AM | #22 |
Thanks again glock. $5.00 part & $9.50 in shipping...yuck! Gotta have it though.
07-17-2009, 11:26 AM | #23 |
Check my post again, I edited it to add more info....
07-17-2009, 11:47 AM | #24 | |
Worst case you may have to remove the rear window channel to allow the glass to slide rearward in the track. I know I had that out to replace the rubber but I just can't remember if that was part of the vent window R&R or not.... K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-01-2009 at 07:08 AM. |
07-17-2009, 11:51 AM | #25 |
Thanks Keith!
Now, get this. I looked at the door glass weatherstrip on my 85 (not the vent window, but the strip that runs along the top and down the back side on into the door), and it also has a one-piece on the passenger side, and a 2-piece on the drivers side. This seems to be a common theme lately, along with mix-matched vent rubber too.
Thread Tools | |
Display Modes | |
