Old 02-11-2009, 08:16 PM   #1
pumpgas
pumpgas's Avatar
Lower A-arm install
How exactly do you know if/when you have these installed correctly? I have taken the entire frame apart am now putting it back together and have no real way to tell if the lower A-arm is installed correctly that I can tell. Any and all help on this would be great.
00' Z28 ("wifes" car)
92' Mustang w/sbc everything needs a little heart beat
87' GMC Sierra Classic Short Bed Fleet side almost stock
69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it
pumpgas is offline   Reply With Quote
Old 02-11-2009, 08:29 PM   #2
Kayotic
Kayotic's Avatar
Re: Lower A-arm install
You asking about the stock arms?
The cross shaft should fit into a little pin.
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 02-11-2009, 08:51 PM   #3
pumpgas
pumpgas's Avatar
Yes factory stock arms just installed new cross shafts in them and now need to reinstall them back onto the frame. I don't see really anything to locate them in a specific location.
Old 02-11-2009, 09:04 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There is a recessed divot in the control arm shaft that will index on a nub sticking out of the crossmember.
Old 02-11-2009, 09:07 PM   #5
pumpgas
pumpgas's Avatar
Ok I thought that might be for something but didn't see the nub on the cross member I'll go look right now. Hope I put the cross shafts in correctly.
Ok after looking at my A-arms I installed one correct and one incorrect and they sit up in the cup and is held in place by the mounting bolt for the cup.
Thread Tools
Display Modes
