Old 02-10-2009, 09:53 PM   #1
phoenix37
phoenix37's Avatar
Eaton Locker
Does anyone know if they make a locker for my HO72 rear axle? Im having no luck finding one.
phoenix37 is offline   Reply With Quote
Old 02-10-2009, 09:59 PM   #2
phoenix37
phoenix37's Avatar
Re: rear locker??
Originally Posted by justcuz View Post
If the snapping and popping you describe, could it also be a clicking type noise? You may have a no-spin aka Detroit locker. The noise is the engagement teeth racheting past each other. Supposedly the locker out of a 14 bolt will interchange with the ones in the Eaton. The difference is the inner axle splines. The Eaton has less splines (17 or 19 I believe) and the 14 bolt has 30 if I remember correctly.
Has anyone done this? I really need a locker for my eaton but i cant find anyone that sells them. Would it be cheaper to swap axles than to buy a detroit for a 14 bolt and new axle shafts?
Old 02-10-2009, 11:18 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Locker for Eaton rear axle?
you'll have a hard time locating anything for an HO rear. I'd look into the avalibility of brakes and drums before dropping big coins on a locker.
You're better off sourcing a 14 bolt or some other rear.
Old 02-10-2009, 11:23 PM   #4
phoenix37
phoenix37's Avatar
This truck doesnt run well in deep snow or mud with an open rear but i think i may need to swap it out for a 14 bolt.
Old 02-11-2009, 07:41 PM   #5
mbgmike
Detroit Locker makes one for it but be prepared to spend over $600.00
mbgmike is offline   Reply With Quote
Thread Tools
Display Modes
