02-12-2009, 01:40 PM | #1 |
Best sourse for replacement power steering gearbox?
My wheel has about 4" of slop in it and it's all from the box itself.
I tried the adjustment on the top of the box, which did tighten it up a bit, but didn't remove much slop. It also caused the pump to start whining, so I'm sure it's too tight. Ever rebuild these, or just ****can it? Rebuild kits are ~$30 assuming that would even fix the source of slop. Looks easy enough to replace, I have a puller for the pitman arm, and everything else just bolts up. I want to get something decent in there, preferabbly no Chinese remans. I used these local guys for my replacement corvette rack, might give them a shot: http://www.meridianautoparts.com/add.../82-00293.html I noticed they also have a "high performance" and "quick ratio" box. I'll have to research that. Rockauto has delco reman's for $195 + core, or A1 Cardont for $125 + core Any other suggestions?
1969 C10 Stepside, 350ci, 700R4 Last edited by CentralCoaster; 02-12-2009 at 01:43 PM. |
02-12-2009, 02:50 PM | #2 |
Re: Best sourse for replacement power steering gearbox?
autozone carries a rebuilt replacement for @ 150
02-12-2009, 04:29 PM | #3 |
Go get you a nice used Quick ratio box from the junkyard for around $40. I think the one I used came from an early 80's model.
02-12-2009, 04:41 PM | #4 |
These meridian guys appear to be operating under several different fronts, this worries me.
They also spam the hell out of online blogs to get more google hits. powersteeringpros.com buy-steering.com discountsteering.com Not a good sign at all. Arggh. I know a guy that works there, I wonder what he'd have to say about that. Napa's website is sucking, as usual. They should have left it alone with the old layout.
1969 C10 Stepside, 350ci, 700R4 Last edited by CentralCoaster; 02-12-2009 at 05:06 PM. |
02-12-2009, 04:44 PM | #5 |
I'm curious about this as well. Napa and the cheapie stores all have a very similar price after the core.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-12-2009, 05:02 PM | #6 |
This guy told me they're rebuilt in Michigan and sell to the local repair shops. He said the Delco units are the exact same overseas crap as the A1 Cardone with a bigger price tag.
He's not exactly unbiased though. I see CCP and red top being mentioned. Someone said they had a CCP unit blow a seal.
1969 C10 Stepside, 350ci, 700R4 Last edited by CentralCoaster; 02-12-2009 at 05:02 PM. |
02-12-2009, 08:11 PM | #7 |
I got one at checkers a couple years ago and it was less than $120.00 And that was for a 4 wheel drive.
02-12-2009, 08:15 PM | #8 |
forgot to mention that I have tried to rebuild them myself and they always ended up leaking or I would have extra parts left over. So the 120 was worth it.
02-12-2009, 08:20 PM | #9 |
That's right, it's Copper!!
Early Classic has one as well. www.earlyclassic.com
02-12-2009, 08:22 PM | #10 |
Who's got steelies?
When I converted from manual, I got a reman box from Oreilly's. Been on nearly 2 years and many thousand miles w/o trouble.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
02-12-2009, 09:28 PM | #11 | |
02-12-2009, 10:15 PM | #12 | |
And they're probably just marking up someone else's unit. Unless they've got their own assembly line in the back office.
1969 C10 Stepside, 350ci, 700R4 |
02-13-2009, 10:37 PM | #13 |
I was recommended to this guy, he's got new variable ratio boxes:
http://www.corvettesteering.com/truck_gears.htm
02-13-2009, 11:36 PM | #14 |
I used this guy in Seattle. Specializes in quick ratio.
I asked for a standard non redhead though. http://www.redheadsteeringgears.com/ |
02-13-2009, 11:59 PM | #15 |
Moderator
I used a later model...one less turn to lock I think. Cost about $100 at a yard.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
02-14-2009, 01:03 AM | #16 |
Check the local boneyards, got a tight and dry box from a 78 for $40 here, fittings fit, turns a little faster, just use the rag joint from the newer box, as shaft is different than the older ones.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
02-14-2009, 01:25 AM | #17 | |
I would stand behind anything they sell and their prices always seem fair, but I dont know much about steering boxes.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
02-14-2009, 09:15 AM | #18 | |
Hand Crafted C-10
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
02-14-2009, 10:54 AM | #19 |
I double checked on the 4X4 steering box at my local checkers and it is up to 175.00 now with a 100 core deposit. They said it had a lifetime guarantee. Can't recall the name of company that rebuit it. (Corman I think)
02-14-2009, 11:47 AM | #20 |
couple years ago, i ordered a whole power steering setup from Powercraft steering parts.
not sure if they're still around, but they were located there in San Diego (chula vista i think), but here's the number on the shirt they sent me 800-698-4443
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
02-14-2009, 01:29 PM | #21 |
Not a bad nut after all..
When my original '71 4x4 box got sloppy I spend $200 after core charge on a reman from Bumper to Bumper (now O'Reilly); it lasted about 6 months before it got sloppy. I've since had this box rebuilt by a local guy with good results.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
02-14-2009, 01:53 PM | #22 | |
Most quality shops won't give you a lifetime guarantee.
02-14-2009, 01:56 PM | #23 |
Red top's website says they just do the seals, bearings, etc.
What about gears? I'm inclined to just buy a new one. Every time I go cheap I end up kicking myself later.
1969 C10 Stepside, 350ci, 700R4 Last edited by CentralCoaster; 02-14-2009 at 01:56 PM. |
Thread Tools | |
Display Modes | |
