Old 12-12-2002, 08:42 AM   #1
Ed ke6bnl
Question S 10 or Camero 5 speed in our Truck
I have been told that I can put a 5 speed overdrive in my boys 70 shortbed c10. Is it true that the s10 and camero 68-? can be used and what list of part do I need to accumulate for the change over from the th350 trans.
Fly wheel
clutch
trans
pilot bushing??
clutch pedal and linkage from stich pu 69-70
Anything wrong with my thinking.
Ed ke6bnl@juno.com
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 12-12-2002, 09:47 AM   #2
Huck
Huck's Avatar
I installed a 96 chev 1/2 ton 5 speed into my 72 a few years ago. It is probably similar to the S10 in that it is aluminum housing, hydralic clutch setup that is really sweet. Not recommended for drag racing but for everyday driving it is super.
Things to consider:
Got to set up clutch pedal and under dash linkage to activate the hydralic clutch master cylinder---must be horizontal into the cyl.
The newer style 5speed has an intergrated bellhousing --remove the old stuff from the engine block back and install the new stuff.
Support the new trans with an "automatic cross memeber" at it's tail.
May need high hump floor with new hole as the shifter mounts forward of stock 67-72 stuff.
Will probably need a re-sized drive shaft which is kind of expensive but~~`.
Depending on year, you may or may not have a speedo gear in the trans verses electronic pickup----I haven't solved that problem yet!!
I bought the whole trans asm including clutch, pressure plate, throwoutbearing asm, clutch master cyl and hose, rear trans universal housing for like $650. Be aware that they have a reputation for bearing noise---check good first then use Mobil1 synthetic dextron trans fluid. Try Dave Hammonds in crab Orchard, Ky @ 606-355-7327 (he parts them out by the 100's)
End result ===drop about 150lbs in weight, drop about 1,000 rpm at highway speed, increase gas mileage from 14 to 18-20.
If you decide, let me know and I can send you picture etc. Huck
Huck is offline   Reply With Quote
Old 12-12-2002, 01:20 PM   #3
dmec
dmec's Avatar
dont use 1 from s10. they are for 6 cyl and have 1 in input shaft and use small clutch. use 1 from camaro/firebird. they have 1 1/8 input shaft and larger clutch. ive been running 1 for 3 years with no problems.
dmec is offline   Reply With Quote
Old 12-13-2002, 01:35 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Main thing to remember on the Camaro one, is the mount is not horizontal...the whole tranny is turned 18 (or so) degrees, and you'll have to fab a mount on your ceoss member to make up for it.
Also, the T5 tranny is not that strong, there is a reason GM never put one behind a 350.
Old 12-13-2002, 03:36 AM   #5
dmec
dmec's Avatar
you dont have to fab a crossmember. you use the camaro bellhousing and the tranny does sit on an angle towards the drivers side. if you use a regular bellhousing the shift lever will be in the passenger seat and you would have to fab a crossmember.
Old 12-13-2002, 06:07 AM   #6
Project1970
14.1 @ 96MPH
Project1970's Avatar
Agreed. Not only was the T5 never behind anything bigger than a 305...the 350 was the TPI, good, but not great...and they felt a 700R4 was strong enough to handle it, but not a T-5.
Now, a T-56, on the other hand, has yet another gear and is VERY strong...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Thread Tools
Display Modes
