Old 02-15-2009, 08:25 PM   #1
justpball
justpball's Avatar
Ball joints????
I tried the search but could not come up with a how to...does anyone have a link?
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 02-15-2009, 09:43 PM   #2
rcbildr
rcbildr's Avatar
Re: Ball joints????
Is it 2wd or 4wd?
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 02-15-2009, 10:10 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Ball joints????
Upper or lower ?
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-15-2009, 10:33 PM   #4
justpball
justpball's Avatar
Re: Ball joints????
2wd sorry and its both
87 Crew SWB
Build for the crew
90 burb 2wd
Old 02-15-2009, 11:04 PM   #5
Mechanic707
Mechanic707's Avatar
Re: Ball joints????
http://www.partsamerica.com/default.aspx
edit:
sorry for the link,
I recently did my 1988 Chevy C3500 2wd.
First I bought a "pickle fork", ball joint press, heavy hammer.
This is what I did.
-take wheel off, take brake cliper off & tie them safely.
-take outer tie rod off the spindle
-remove ball joints and press in.
hope the videos help
1977 GMC C2500 5.7L V8 Long Bed 4-Speed Stick 12/08
~12/08 Sanded/Primed/Rhino Lined inside bed
1988 Chevy C3500 5.7L 1-Ton w/utility bed10/08
~1/09 Tie Rods, Ball joints, spindles, wheel bearings, steering gearbox
~11/08 distributor, cap, rotor, wires, plugs, thermostat 180' & chrome water inlet, radiator flush, hoses, Trans filter & pcv, air & oil.
~11/08 Sanded & painted blue. new brake booster & master cylinder w/flush & adjust.
~Bought 285/70/16 orig. chevy rims w/tires on C/L$100
Mechanic707 is offline   Reply With Quote
Old 02-15-2009, 11:21 PM   #6
justpball
justpball's Avatar
Re: Ball joints????
no how to's on there...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 02-16-2009, 11:59 PM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Ball joints????
There are good instructions in the "garage" section of 73-87.com
Basically you need a press for the lowers. You can buy one at Harbor freight for $40-$50, or most auto parts stores loan them out. If yours has "hogged" the hole out like mine, there is an oversized one available.
The upper, if original, is riveted in. You'll have to torch, grind, or drill out the rivets. The replacement bolts in.
Of course, you have to remove them from the spindle as well. there are instructions for that on 73-87.com. It isn't my preferred method, but it will work. One of these days I'll write up the instructions I promised Jeff for the site over 18 months ago... :-(
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 02-17-2009, 01:57 AM   #8
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: Ball joints????
Here's a couple of PDFs that I put together over a couple of years ago. The instructions are both over 1,000s of words long since they both include some pics.
Slon-
I tried to convert these instructions to HTML for Jeff, but for some reason, he couldn't read them. (I guess I should have reported this to Marc Andreessen. )
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 02-17-2009, 10:32 AM   #9
justpball
justpball's Avatar
Re: Ball joints????
thanks so much guys!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 02-18-2009, 01:14 PM   #10
Slonaker
Slonaker's Avatar
Re: Ball joints????
Slon-
I can probably extract the text and images from those PDFs so that he can use them however he needs if it would help. If you want me to do that, PM me an email address to send them to. I don't have much time to spend on the forum any more, so this thread would probably be on the 10th page or something by the time I got back here...
Slonaker
Stock '01 Silverado
Old 02-19-2009, 01:48 AM   #11
boxrodz
boxrodz's Avatar
Re: Ball joints????
Slonaker
Thanks for the offer, Slon. I actually have all the pics and text in (HTML) source code and they actually come up fine in my browser when I tested it, but Jeff had trouble with the source code and associated files when he tried to host them the 73-87.com site. We never did figure out the issue. BTW, I can certainly relate to the lack of time.
Back on topic,
Here's a past thread regarding the UCAs and the LCAs:
http://67-72chevytrucks.com/vboard/s...d.php?t=189574
boxRODz
Thread Tools
Display Modes
