Old 02-18-2009, 11:14 AM   #1
rex01atv
What size airline to use?
I cant decide what size airline to use 1/4'' or 3/8''? I want to use 3/8 but I'm concerned that when I hit my switch it will be to quick for me to adjust for the right amount of airpressure? Any feedback woul help.
rex01atv is offline   Reply With Quote
Old 02-18-2009, 11:19 AM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: What size airline to use?
You'll be happy with 1/4.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-18-2009, 11:36 AM   #3
OrangeAnimal
OrangeAnimal's Avatar
My opinion is 3/8 in the rear and 1/2 in the front.
OrangeAnimal is offline   Reply With Quote
Old 02-18-2009, 12:05 PM   #4
theyammieguy
accepting donations
theyammieguy's Avatar
This has concerned me as well. I want to be able to pop it up pretty quick but also need the ability to make precise adjustments
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 02-18-2009, 02:32 PM   #5
OrangeAnimal
That is why u use 3/8 in the back and 1/2 in the front. It will be very slow on 1/4.
P.S. the yammie guy, I like that quote.
Old 02-18-2009, 05:32 PM   #6
theyammieguy
accepting donations
Are you still able to air it up to an exact pressure?
David Crockett
Old 02-18-2009, 05:40 PM   #7
Kayotic
Kayotic's Avatar
This is never going to end.....
You are just going to have to try different lines..
I have 1/2" fittings at all four bags. 3/8" air line and the ports on the tank are also 1/2".
Sorry I don't have a direct answer - but this is what I am going to start with....
-My 2cents -- 1/4" air line is a little small. The plastic line I have is measured on the outside. So the I.D of my 3/8" line is a tad over 1/4".
I wasn't expecting that at all.
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 02-18-2009, 05:45 PM   #8
cdowns
cdowns's Avatar
i dont use airlines that have anything smaller than a 747
Old 02-18-2009, 10:57 PM   #9
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I have 1/2", and it is fast. I think you will happy with 3/8".
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 02-18-2009, 11:07 PM   #10
Twisted Minis
Twisted Minis's Avatar
I run 3/8" valves and 3/8" line. It lifts up plenty fast in the front. Not abrupt, but fast enough for me, and I can usually adjust to my desired height in one switch. For the back, it was a tad fast for my taste, with the bags being in a leverage ratio and not much weight. I got some stiff ball valves and put them right after the valve, and adjusted it until ti felt right to me.
The dump was always too fast for me, so I got some 3/8" plugs and drilled an 1/8" hole in them. The back is a bit larger (3/16") since the ball valves slow it down a bit too.
However, I prefer a pretty slow setup myself. I hold down the dump for about 5 seconds to air all the way down.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 02-19-2009, 09:20 AM   #11
OrangeAnimal
Twisted has the right idea. You can tailor the speed to your liking. There are many ways out there to control the rate of rise and drop. For ball valves and orifices check out http://www.mcmaster.com/#
Old 02-19-2009, 09:44 AM   #12
Tony@AirRideTech
Junior Member
For me personally.... 1/4" is plenty. An optimized 1/4" system will lift a vehicle in the 2.5-3 second range. Plus 1/4" is a heck of alot easier to route and plumb.
Now if you think you are wanting to go faster but are worried about making it to fast... there is actually an easy cure for that too. If you are running 1/2" airline... to slow it down just cut you off about a 10" piece of 3/8 airline and cram it inside the 1/2"... if you still want to slow it down from there... cut you off a pice of 1/4" airline and slide it inside the 3/8. if you ever want to pick the speed up again all you do is take a pice of coathanger wire bed a little L on the end of it, slip inside the line, hook the end and yank it out. Or spend a few buck and get a flow control valve.
Tony@AirRideTech is offline   Reply With Quote
Old 02-19-2009, 09:58 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for sharing that Tony. I have heard of many ways to slow a system down, but that is the simplest, and cheapest yet. More importantly it is easy to reverse if you go to far with it.
Please describe what you would consider an "optimized" 1/4" system?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-19-2009, 12:05 PM   #14
c10addict
c10addict's Avatar
I have 3/8 with ART Big Red Valves on my 68 and love everything about it... I have 1/4 on my 64 and it seems a little slow to me.. I bought another set of ART Big Red Valves and 3/8 line for it and will put them on soon...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 02-19-2009, 12:41 PM   #15
smashingchuck
While on the subject of slowing the system down, I tapped the inside of my fittings, and simply ran an allen style pipe plug into them with 1/8 holes drilled in them. My truck lift nice and easy now, and I didn't have to buy new valves. For the record, I'm running 3/8 hard line.
78 Build Thread
4Runner Build
Old 02-19-2009, 06:04 PM   #16
tds
me personally i'm gonna run 3/8 line and ride as low as ****ing possible. so i'm gonna have fast fills, so i can jump at a decent pace if i need to corner hard or dodge a pothole hole or somthing but then probably choke my 3/8 dumps down to 1/4 or smaller and just float down.
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
Thread Tools
Display Modes
