02-18-2009, 11:22 AM | #1 |
Dash lights
I replaced all the dash lights on my 67 and took my first night drive afterwards and I can't see sh*t. Is there any other bulb that will work other than the one listed for it? The one that lights the indicator just barely lights the pointer, but not enough to tell what gear I'm in. I guess just because they are new doesn't mean that they work. I'm going to check them all again, but I would like to replace them with brighter ones if available. Thanks
02-18-2009, 11:23 AM | #2 |
72 chevys 4 life
Re: Dash lights
on my pointer light there is a thing that goes over the bulb a lil plastic thing i took mine off and it brightened it up alot.
I dont call it being young and dumb....I call it young and havin fun |
02-18-2009, 11:25 AM | #3 |
Re: Dash lights
This may be a stupid question, but have you adjusted the brightness by turning the headlight knob?
This got me a time or 2 in my BMW and in the pickup, I'm not used to that setup. But twisting the headlight knob adjusts dash light brightness. |
02-18-2009, 12:45 PM | #4 |
Re: Dash lights
I did try the bright/dim on light switch but no luck. I was even going to replace the light switch to see if that would help, but I was told that if the lights were working then the switch was OK.
02-18-2009, 01:24 PM | #5 |
Restoration Virgin!
Re: Dash lights
Hey easy rider....did you check and be sure you have a good ground from your dash bezel plug....that might help you out....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
02-18-2009, 01:34 PM | #6 |
Re: Dash lights
I haven't checked that yet, Thanks!
Thread Tools | |
Display Modes | |
