Old 02-18-2009, 02:06 PM   #1
cochino12
It followed me home?
cochino12's Avatar
Did 6.2 diesel use hydroboost? same as small block?
I'm trying to find a hydroboost bracket for a sbc but Im not having much luck finding anything in town here. Someone told me the diesel trucks used hydroboost and the brackets are the same as a small block? Any input ?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-18-2009, 08:52 PM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Did 6.2 diesel use hydroboost? same as small block?
Isn't hydroboost the system where the brakes and steering are "hooked" together? If so, then yes. My K10 has it.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-18-2009, 08:56 PM   #3
D13
D13's Avatar
Yes, and so did many 1 tons and 2 tons.
I'm assuming you are talking about the firewall bracket, right? Because you would use the SB pump on a SB. Yes the diesel and 1 ton firewall set ups are are the same as SB. Your best bet is to find a complete unit so as to get the right rod set up and the hoses for the PS, which get expensive to have made.
I'm not sure the 2 ton hoses work although the booster and rod set up are probably the same. I'm pretty sure the one on my 87 1/2 ton diesel will directly interchange with my 87 C65, but the hoses are different length.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-18-2009, 09:20 PM   #4
Russell
Professional Grade
Russell's Avatar
The boosters are the same between a gasser and diesel, but the pumps and brackets are different between the two.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-19-2009, 12:15 AM   #5
cochino12
cochino12's Avatar
I yanked the original 454 and replaced it with a 350 so I need a new bracket for the small block pump. GM says there is only one style bracket for a sbc hydro boost p.s. pump, I just wasnt sure if the diesel brackets would work on a sbc.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-19-2009, 07:47 AM   #6
D13
D13's Avatar
No, the brackets won't swap 6.2 to SBC to BBC. And the pumps are usually different (orientation of the return line, pulley, etc.). But there is noting unique about the hydroboost pump, so whichever SBC bracket and pump would normally fit your engine would be fine.
1987 2 ton
Old 02-19-2009, 09:04 AM   #7
cochino12
cochino12's Avatar
Thanks for your help D13, I'm not understanding your explanation though. You say the pumps are different as far as return line... but a factory sbc p.s. bracket from my year truck should fit around the hydroboost pump?
I guess that means I have the wrong pump then? I have a bracket from a 79 sbc and it doesnt fit around the new hydoboost pump that I bought. I'm
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-19-2009, 09:48 AM   #8
D13
D13's Avatar
Not dumb at all, GM built dozens of PS pump combos with different brackets and reservoirs, often just beacuse they could. Does your pump have 2 return pipes? Because the pump 'guts' are all the same, so I'm assuming the problem you are having is in the fit of the brackets around the reservoir? And the difference in reservoirs is usually the return lines, occasionally the 'clocking' of the pump in the reservoir.
Ah, I see by an auto store parts list that you probably have the dual return line...
On my 99 the pump feeds 1 circuit, and hydroboost or not doesn't matter. Single return line. Diesels are almost always hydroboost, my 87 uses a single return line plus a big (like 1") line to a remote reservoir. My 87 gasser is a tall deck BB with the remote tank so no love there.
Can you describe what part of the bracketry doesn't fit? If the second return line interferes would a minor notch in the bracket fix it?
Only place I have ever seen SBC hydroboost is on 350 powered dually or C50. So that would be where I would J-yard pick.
Other option would be to use the single return housing and T the return hoses in front of it. The issue would be sluggish response if braking and turning hard simultaneously.
1987 2 ton
Thread Tools
Display Modes
