Old 02-22-2009, 08:15 PM   #1
70Custom10Nut
70Custom10Nut's Avatar
Question starter engagement
I just bought a tilt column off e-bay in December and of course after cleaning it up and painting it, I put it in my truck. Everything works fine except for one thing. Sometimes when I'm shifting back into park, the starter engages for a second when the indicator is near reverse. It doesn't do it all the time and as soon as it is in park it stops. Has anyone out there had the same issue? Is it something I did when I put it in? Do I just need to make a linkage adjustment? With the ignition switch on the dash how is it possible for the shift linkage to effect the starter. I really hoping my only ever e-bay purchase is NOT the culprit somehow.
70Custom10Nut is offline   Reply With Quote
Old 02-22-2009, 09:04 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: starter engagement
The only thing I can imagine that it would be is that the neutral start switch reverse light wire is touching the purple solenoid wire when you get near the reverse indicator.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-22-2009, 09:34 PM   #3
70Custom10Nut
Could be, because the neutral switch may not be hooked up right. any pointers on how to confirm. If these wires are crossing what is the fix? Is it a major issue to fix? Thanks, Cnut
Last edited by 70Custom10Nut; 02-22-2009 at 09:49 PM. Reason: needed to add another question
Old 02-22-2009, 10:26 PM   #4
Sammy
I think your going to have to down load from FAQ the diagram chase wires. Pay attn to the starter wires especially between the neutral safety switch n ignition switch. Might even be a faulty neutral safety switch??
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-22-2009, 10:51 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
here it is . The NSS is in the center. Notice the dark green and light green wires on the reverse switch and the purple wires on the starter solenoid side.
VetteVet
Old 02-22-2009, 11:51 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
vet's explination is the only possible thing i can think of too.... Even so, it seems remote.
Thread Tools
Display Modes
