Old 12-13-2002, 06:59 PM   #1
Cliff
Heat
Hello everyone, well it's gettin kinda chilly up here in PA, and I have a slight heating problem i thinkg. I have AC but it is not hooked up.... and I have heat blowing out the defroster vents which is pretty darn warm. No complaints there. The problem is that cooler air is blowing out the center AC vent and the other 2 AC vents as well. It keeps the truck warm, but never ROASTING hot. I think if i could find why the air is cooler in the AC vents the problem would be solved. I just recently replaced my heater control unit due to some broken levers. . Thanks a ton for the help... The truck is a 1972. Cliff
1972 Custom deluxe 305/350 C/10 8-foot bed with 1/4 inch diamond plate steel bed floor.
Cliff is offline   Reply With Quote
Old 12-13-2002, 07:29 PM   #2
barn9
Half a bubble off!
barn9's Avatar
I would suggest taking apart your heater box, etc. and checking the flaps and cables, etc., and give it a good cleaning. Not uncommon to find leaves and other assorted things that have made it into the works. Good luck!
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 12-14-2002, 02:26 AM   #3
Cliff
Any other ideas ? thanks again in advance
Old 12-14-2002, 02:28 AM   #4
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
small fire on the passenger side? hee hee sorry!
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 12-14-2002, 04:00 AM   #5
BUXMAN66
go bucks!
check to make sure your hoses are hooked up to the mounting flanges ok........just trying to keep topic ttt.
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 12-14-2002, 10:46 AM   #6
Andy4639
Old member
Andy4639's Avatar
Cool Heat?
You didn't say anything about what it does when you have it on heat. FLOOR does it have hot are warm air. If it doesn't get hot I would suggest looking at your cables and making sure they are all working correctly, that they open are close all the way. Also check the flapper doors to make sure they are working right. The vacuum hoses are hooked up right. Hope this helps.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-14-2002, 10:55 AM   #7
hanssolo
hanssolo's Avatar
One thing to check on old flappers is sometimes the rod moves but the flapper does'nt because its so loose.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Thread Tools
Display Modes
