02-25-2009, 09:27 PM | #1 |
Gears vs Transmission
So I did some inquiring and if I wanted to swap out the 3.73 gears to a 3.42.. this is the overall costs involved:
3.42 gears will run you $197.96, bearing kit $106.92 and 4-5 hours labour $380-$475. I can pick up a used 700r4 off craigslist for $150-200 if I watch carefully and get it rebuilt for slightly more! No wonder a lot of people just do the transmission route! |
02-25-2009, 09:51 PM | #2 |
Slugish
Re: Gears vs Transmission
you can get a 700 r4 buily for slightly more than 200.00 > tell him to move his shop to Virginia . My trans guy ( who has done good work for me before ) says it would be around 1ooo.00 - 1200.00 > thats including evereything - all labor of removing & reinstalling .
02-25-2009, 10:41 PM | #3 |
Why are you going to switch from a 3.73 to a 3.42? MPG?
Your not going to get much of a 700R4 for that kind of price. If you want a 700R4 that is going to take a good beating without having any problems then you will be spending over a grand.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
02-25-2009, 10:45 PM | #4 | |
I'm just looking at my options. |
02-26-2009, 09:05 AM | #5 |
Happy to be here
Just for point of reference, regardless of what transmission your running the difference between 3.73 and 3.42 is 1-2 mpg. It "might" be a bit more with your current 3 speed. The OD transmission should give you better mileage than the gear change, but doing both would be best.
With that said, consider how many tanks of gas it will take to recover your costs. If you don't need a transmission, then the best bang for your buck would be a gear change. I would search the bone-yards for a rear axle with 3.42 gears. Pop the cover, inspect for damage, replace the gear lube and go down the road. You can buy used axles for a lot less than a gear or transmission swap.
02-26-2009, 12:32 PM | #6 |
I think Ken's idea is a pretty good one. My uncle has 2 79 c-10, and both are sixes with the 3 speed and 3.42 gears. I don't know if this is just a coincidence, or if that was the gear ratio for that set up. Either way, it is a good place to start looking. Most sixes of that era died from the intergral head crapping out, not being gutted pulling stuff.
02-26-2009, 12:42 PM | #7 | |
02-26-2009, 12:54 PM | #8 |
Project '67 454
I don't know how much acceleration you're willing to give up but a used 3.08 for a couple 100 bucks found in many later model trucks would would work good on the interstate without changing the transmission
02-26-2009, 01:08 PM | #9 |
I agree with Ken idea of finding a used rear with 3.42 or even a 3.08 gear set. Ultimately, if you're looking to spend a grand for better fuel efficiency, buy an econo-box!
Edit: yay for finally breaking 1000 posts!
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 Last edited by C-10volvo; 02-26-2009 at 01:09 PM. |
02-26-2009, 01:10 PM | #10 | |
All I'm looking for is to drop my rpms a bit on the highway and gain a bit of mileage. |
Thread Tools | |
Display Modes | |
