Old 02-27-2009, 01:13 AM   #1
ca180
tryin to get laid
shaved handles
Forgive me if this has been gone over. I'm sure it has. It's one of those "how do I slam my truck the ground and still pull a gooseneck!?!?" kinda threads .
Anyways, I don't seem to be able to find what I'm looking for.
To the point.
I wanna shave the handles, but don't wanna go electric solenoids. Anyone here ever kept the key to open the latch? I was thinking there would be a little too much pressure and might break the key off in the lock.
Ideas, comments, concerns?
ca180 is offline   Reply With Quote
Old 02-27-2009, 03:20 AM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: shaved handles
Put the power windows on the alarm.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-27-2009, 03:36 AM   #3
OARNGESI
OARNGESI's Avatar
Re: shaved handles
Ive seen people put a key under the back window to unlock the door then a buttonin the bed to actully pop the door open
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-27-2009, 08:43 AM   #4
andrewmp6
Re: shaved handles
Or even rig up a cable latch under the truck like most cars have for a hood latch.A lot of really low trucks i seen mount there gooseneck on top of there c notch.
andrewmp6 is offline   Reply With Quote
Old 02-27-2009, 08:48 AM   #5
ca180
tryin to get laid
Re: shaved handles
Nice...
I'm not really wanting to do anything electronic. Including power windows. And cables can be too obvious when you're at the store...
Old 02-27-2009, 09:07 AM   #6
wicked_sky_gazer
Living Legend
wicked_sky_gazer's Avatar
Re: shaved handles
I have seen some guys here local (tulsa) run the cable into their front fender wells and hide them pretty good, to the point that they just reach in and the door pops and it leaves you wondering how/what they did to work it. but i have no idea how they accomplished it
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia..
project is temporarily on pause again... Thankyou wonderfull economy.. check it out
Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap
East Ok meet East Ok date
Tony
wicked_sky_gazer is offline   Reply With Quote
Old 02-27-2009, 09:24 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: shaved handles
Well you could always leave your vent window unlocked and reach inside.
Realistically, your looking in the wrong direction. Do you really want to depend on a key to be sturdy enough to unlock your truck? It's not going to last, and your going to be standing outside your truck holding a nub with a really frustrated look on your face.
Do it once, do it right, and be a happy camper...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-27-2009, 10:16 AM   #8
454HO
Re: shaved handles
The electric solenoid is pretty fool proof.... unless you leave the headlights on and drain the battery. Then you are kinda screwed unless you can pop the hood and put a charger or jumper cables on the battery.
Just remember, anything you do to make it easier for you to get in also makes it easier for a crook to get in.
- Greg
454HO is offline   Reply With Quote
Old 02-27-2009, 10:51 AM   #9
1984 swb chevy
1984 swb chevy's Avatar
Re: shaved handles
I did use my door lock and I tried to hook up a pull cable fron the lock arm and it did work for a while but I had some problems with the arm on the lock cylinder. The arm would get sloppy so I took it apart and ran solenoids. That was a long time ago and I was much younger and did not take the time to work it out . You may have better luck.
2010 Tahoe
1984 C10
2005 Harley FLH
1941 Willys Pickup (will never get it done) not for sale
1984 swb chevy is offline   Reply With Quote
Old 02-27-2009, 01:39 PM   #10
piecesparts
Parts and more parts
piecesparts's Avatar
Re: shaved handles
I saw a truck that had a rdo go through the bottom of the cab and there was an assembly that the owner just put his foot on to pull the latch. This would work well with the "Bear Claw latches that has the latch mechanism in the cab "B" pillar and NOT the door.
piecesparts is offline   Reply With Quote
Old 02-28-2009, 02:01 AM   #11
HanSoloWS6
HanSoloWS6's Avatar
Re: shaved handles
Since you don't want electric, I'd go the cable route. Just using the key in the lock won't be reliable over time. Either the key will break, or the lock will get sloppy, as mentioned.
"Locomotion" - 1982 C10 LWB
6.2 to 6.5 HUMVEE non turbo swap complete
Pop's Garage Photography - Dayton, Ohio
My Truck Build Page
HanSoloWS6 is offline   Reply With Quote
Thread Tools
Display Modes
