newer 6 lugs for 1969 swb chevy will they fit?
Re: newer 6 lugs for 1969 swb chevy will they fit?
yeah, They should both be 6 on 5.5 and the backspacing for disk should be more room then need for drums anyway.
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build Last edited by Sinisterspeed; 02-28-2009 at 01:51 AM. |
I have a radical idea!
Welcome to the site!
I know they will bolt on because I put a old set of 15" Rallys on my 2000 Z71, but I don't know if the offset would be right. I know the pattern is that same though.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
its all about the +6 inches
not a direct bolt on, no. You'll need to hog out the center hole, and then the back spacing will be way off. You could use spacers, but it's not a good idea.
the back spacing is off by at least an inch, i had a set of rims from my 01 that i used as rollers for a while they bolted right up but in order to have my full turn radius they needed more back spacing
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
Eat My Rust
You'll need to machine the wheel hubs, and get spacers for the rear. May get away with out spacers up front though, I could've.
cool thanks guys
Thread Tools | |
Display Modes | |
