Old 02-28-2009, 03:18 AM   #1
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
1987 Tach question again.
http://cgi.ebay.com/ebaymotors/80-81...3A1|240%3A1318
Was this a good buy guys? Not the price, but did it make sense to find one with all of the wiring? I am new to this era truck style, but I have a 1987 Fuel injected 1 ton 4x4 and was wanting a tach very badly for it so I have been watching evilbay and bought this one. The truck currently has a normal gauge package without tach and has a 454 tbi, 400th auto, and a 205 tc. I know several people have made them work, but I am wanting to know if I will have to completely rewire this dash to work, or if it will be a lot easier since it comes with the original wiring with it? Will I be able to just splice it in to the existing harness wires? Thanks Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-28-2009, 03:34 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: 1987 Tach question again.
Well it looks like you got a good deal there. Looking at the pics, The first thing I would recommend is moving the light in the lower left warning light hole back up to the upper left hole where it belongs as the lead comming off of it is a fiber-optic light for your ashtray.
As for doing a dice-n-splice, not needed nor recommended. All you have to do is make a list where each lead goes to then simply repin the connector on the harness in your truck to match it. Use a small flat tipped jewlers screwdriver or a small pick to push the connectors out and swap them around. The only harness you WILL have to use there is the one for the tach itself.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-28-2009, 01:47 PM   #3
sierra4x4
sierra4x4's Avatar
Ble 'Burban is right about switching the pins in the connector plug You shouldn't have to change many. Another thing you will need to add is the VSS(vehicle speed sensor) that mounts beside where the speedo cable goes on.
sierra4x4 is offline   Reply With Quote
Old 02-28-2009, 03:50 PM   #4
71blksuper4x4
SWB 4x4 Collector
Sierra, do I need to actually use the speed sensor? With having the 205tc and the 400 in my truck, I can plug it in directly don't I? I don't have a 700r4 and the 208 or 241 in my truck. Trevor
TREVOR
Old 02-28-2009, 10:56 PM   #5
BLE 'BURBAN
Have you got cruise control? If so then you will need the sensor hooked up in order to use it. May be as simple as swapping the speedo heads between the clusters along with maybe drilling a mounting hole or 2. Just take a good cose look at the back side of the clusters to see what you may need to do in order to make it work.
Old 03-01-2009, 09:33 AM   #6
sierra4x4
sierra4x4's Avatar
I think this is where the computer gets its speed signal from also. It will all swap over right off the old speedo cluster.
Old 03-01-2009, 02:27 PM   #7
71blksuper4x4
SWB 4x4 Collector
Sorry about my post yesterday, I wasn't really thinking when I wrote I have a 400th auto trans when I actually have the 465 4 speed. I have been doing so much reading about the 1 tons and the other trucks that I have, I blurted out the 400. Sorry about that guys. The truck is a 1987 Silverado 1 Ton 4x4 with the 454 tbi, 465 4 speed, and the 205 transfer case. It does not have cruise control though, so I should be fine without using any of the speed sensor stuff correct? Trevor
TREVOR
Old 03-01-2009, 03:41 PM   #8
BLE 'BURBAN
It would be best to hook it up. Shouldn't be to hard to do.
Old 03-05-2009, 06:00 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Nothing much to add other than you can swap you current speedo over if it has the signal on it.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Thread Tools
Display Modes
