Help with removing my dash
Sorry if this is in the wrong spot but im trying to remove my dash in a 1970 c-10. MY question is do I have to remove my winshield I took all the bolts on the sides out and it seems to be stuck at the top and from what I can tell the lip of the dash goes behind the winshield molding. Any help you guys can give will be great. jack
Re: Help with removing my dash
it is welded to the cab at that point at the windshield
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
I'm not 100% sure, but I thought the dash was spot welded to the top of the firewall @ the windshield molding.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Alright thanks guys I just wanted to take it out to make the wiring job easier but i guess ill work around it thanks for the quick reply. jack
Yeah, and because of the angle where the spot welds are, it can get kinda messy.
I have a bare cab I removed on out of and still had a hard time. Need to have the correct tools for the job, spot weld cutter or - What's that other name = starts with a "B" i think? After Thought: "Broach" or "Rota Broach" Second Edit: Their from ![]() Last edited by Kayotic; 02-28-2009 at 12:41 PM. |
Old Skool Club
![]() Join Date: Jun 2001
I think the assembly manual shows 27 spot welds.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
![]() Join Date: Sep 2006
I drilled out 32 spot welds to get one out of a donor truck. Not fun.
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
Thread Tools | |
Display Modes | |
