Old 03-01-2009, 05:09 PM   #1
kcackler
Dashboard/Cluster questions
I recently purchased a 77 Chevy Pickup (Scottsdale) and am slowly but surely working on fixing the various issues that I'm finding.
The first thing I've decided to tackle, since it's hopefully one of the cheapest, is the fixing of various gauge issues the truck has. Here they are in no particular order:
1 - The gas gauge always reads above full. I assume the sending unit is out?
2 - The speedometer is loose, for lack of a better word. When driving, the speedometer may fluctuate 5-10 MPH, even when the speed is constant. When I force the gauge up and let go, it just slowly falls back down. Is it not supposed to snap back down to 0 more quickly? Maybe the cable from the tranny is worn out?
3 - The temperature gauge only moves a little less than a notch for some reason. It's obviously somewhat working, because when the truck is warmed up, the needle is off of the C, but it's nowhere near where it needs to be.
4 - The most frustrating - The gauge lights are very loose. I replaced a few of the bulbs, but had to wiggle them just right to get them working. I've got a feeling that the first time I hit a nice bump, they'll get loose again. Is there any way to tighten the sockets that they go into?
5 - The gear selection needle is broken. It's obvious that the needle is supposed to connect to the steering column with something, but I've got no idea what. Right now there is a string tied to the needle, but it's not connected to anything. It was obviously an attempt at fixing it.
6 - Is there anywhere that I can buy a new dashboard for the truck? The current one is old and beat up and sun damaged and cracked, and looks like crap. Is there anyone that makes replacements?
I think that wraps up my dash questions for now. Any help or advice is much appreciated.
kcackler is offline   Reply With Quote
Old 03-01-2009, 05:35 PM   #2
Vixvega
Re: Gauge Issues
LMC truck or Classic Parts are 2 good places to start. Bring your checkbook. Or check with some local wrecking yards, some places have a soft spot for these trucks. We have a place that has never crushed a car, 5000 of them from the 50s to today.
Vixvega is offline   Reply With Quote
Old 03-01-2009, 06:07 PM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Gauge Issues
Replacement sockets are available at NAPA under part # LS6501 to fit the larger openings (5/8") and LS6500 for the smaller openings(1/2")
Generally the smaller ones are used to replace socket/bulb combo part # PC194 since you can't replace just the bulb in them and they can be hard to find at times.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-01-2009, 06:14 PM   #4
BLE 'BURBAN
Re: Gauge Issues
This is what it should look like on the end of the "string. It simply slides onto the lower portion of the steering column shroud.
Old 03-01-2009, 06:23 PM   #5
kcackler
Re: Gauge Issues
Thank you for that picture. I now see that my "string" is the correct part, but it's snapped, which is why the needle isn't moving. If you know where I can find a replacement "string", I'd appreciate it. If not, it looks like I'll be buying the whole assembly (Which I can't imagine is too expensive..)
Old 03-01-2009, 06:31 PM   #6
BLE 'BURBAN
Re: Gauge Issues
LMC carries the PRNDL indicators
Old 03-01-2009, 06:37 PM   #7
kcackler
Re: Gauge Issues
Already placed my order - Thanks
Thread Tools
Display Modes
