Old 03-10-2009, 09:11 PM   #1
blown luv
dumb radio?
ok heres my problem. 86 chevy 3/4 ton.2wd with 3" body lift.When I bought the truck radio had alot of static.So I changed the antenna,nothing changed,swapped out speakers,still static.Pulled the sony out of my vw bug that was working great.Put it in the truck STATIC!Tried 3 diffrent antennas ,still static.The wiring on this truck is hacked,so I ran a new power wire straight to the battery and a ground wire to the bottom of the dash,same thing.Found the ground stap from body to engine off made a new from firewall to engine and 1 from body to the frame.Same problem.ANY IDEAS???Thanks
blown luv is offline   Reply With Quote
Old 03-10-2009, 10:36 PM   #2
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Re: dumb radio?
Blown: I kept getting static in my truck until I kicked my old lady to the curb and - Voila! - no more static. But back to your problem... I had to install an inline filter on the power side of the radio to cure the static problem in my truck. Believe I got it at Radio Shack, but any car stereo installation shop should carry them. Otherwise, it sounds as if you did your homework on your truck's wiring situation. Good luck.
78 Big10 454 is offline   Reply With Quote
Old 03-10-2009, 10:47 PM   #3
blown luv
Re: dumb radio?
Thanks man!!! going to radio shack tomorrow. I would never dream of kicking my wife to the curb ,she knows I'm a sound sleeper and where the guns are. lol. thanks again.
Old 03-10-2009, 10:55 PM   #4
grinch4om
dang its hot
grinch4om's Avatar
Re: dumb radio?
check your body to frame grounds, theres one on the body under the drivers rocker panel towards the rear of the cab and check for one from the engine to the cab
grinch4om is offline   Reply With Quote
Old 03-11-2009, 08:59 AM   #5
fast75
Go Hard or Go Home!
fast75's Avatar
Re: dumb radio?
get you an inline rf filter
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
fast75 is offline   Reply With Quote
Old 03-11-2009, 11:20 AM   #6
James McClure
One shot, one kill.
Re: dumb radio?
If it's a "whine" that changes with RPM, it's comming from the alternator and a filter will fix it, but be forewarned, the alt has a problem. If it's a steady "pop,pop,pop" type noise it is from the secondary Ign circut, EG, cap, rotor, wires or cracked plug insulators. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-11-2009, 08:38 PM   #7
blown luv
Re: dumb radio?
Grinch, I installed new ground straps 1 from the body to the frame,and 1 from the body to the engine block.It's not an rpm noise its plain old static. Rpm doent change it. I will check on the rf filter.The guy at radio shack tried to sell me a ground loop isolator,but it didnt look like it wouls hook up with out cutting it,so Im still researching.THANKS GUYS!!!
Thread Tools
Display Modes
