Old 03-11-2009, 06:54 PM   #1
brian69longbed
brian69longbed's Avatar
SHOCKS front and rear
Is kyb a good shock choice when just putting bags in place of your springs? and where should i locate them on the rear? i've removed the rear shock mount support/crossmember for the bag install to the frame. do i need to put in a crossmember with some bolts welded to it??? pictures always help
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
Old 03-12-2009, 08:27 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: SHOCKS front and rear
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-12-2009, 11:55 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
They're OK...a little bit stiffer ride than the Monroes. I run QA1 adjustables at all four corners.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Thread Tools
Display Modes
