Old 03-12-2009, 12:18 AM   #1
jklonowski
jklonowski's Avatar
unlevel drop from side to side?
hello i had a 2 inch coil /4 inch shackle and hanger drop put on my truck and it just doesn't look correct. the passenger side has more of a gap between the fender and the tire on the front and back than the driver's side does. i don't understand because the coils should have dropped the same on both sides. and the hangers are adjusted to make the truck as low as possible on both sides. i just don't understand why.
what also confuses me is that when i am standing behind the truck the bed is not level with the rear glass. there is more of a gap between the glass and the bed on the passenger side (which also has more of a gap between the tire and fender)than on the driver's side? i just don't get it.
can anybody understand and give me feedback
jklonowski is offline   Reply With Quote
Old 03-12-2009, 12:25 AM   #2
jklonowski
jklonowski's Avatar
Re: unlevel drop from side to side?
also at first i tried to put on 3 inch drop spindles and when i turned the wheel all to the left or right the rim would hit the lower control arm. i was using 17 inch torque thrust. i don't understand because ive seen the same trucks with a 3 inch drop spindles with 15 in wheels.
Old 03-12-2009, 12:37 AM   #3
94tx
94tx's Avatar
Before I got my C10 I was into S10's and Blazers. From what I understand from your post, you seem to be talking about the "chevy lean." Every Chevy truck/suv my family has owned (going on 7 now, from s10's, blazers to full sizes) has always leaned lower on the driver side. I don't think I've seen a deffiante answer, but it seems to be a common concern on the "mini truck" forums.
94tx is offline   Reply With Quote
Old 03-12-2009, 12:45 AM   #4
OARNGESI
OARNGESI's Avatar
I never heard of the chevy lean could it be the body mounts are sagging and its just more noticible now that the gaps are more filled in
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Thread Tools
Display Modes
