Old 03-16-2009, 12:50 AM   #1
rookierodbuilder
rookierodbuilder's Avatar
frame perches for cab mounts. Will these fit?
I am currently assembling a short bed frame for my 66 pickup and have a problem. My cab mounts on both the short bed frame that I got from my parts truck and the ones on my 66 are rotted. I am wondering if these 67-72 units from brotherstrucks will fit. any feedback will be much appreciated. Here is a link to brothers' cab mounts page:http://www.brotherstrucks.com/products.asp?dept=919
rookierodbuilder is offline   Reply With Quote
Old 03-16-2009, 04:13 AM   #2
LILRED66
LILRED66's Avatar
Re: frame perches for cab mounts. Will these fit?
They are not the same, but they will work.
Welcome to the forums from Kansas City, KS and keep us posted on the progress of your project.
LILRED66 is offline   Reply With Quote
Old 03-16-2009, 09:06 AM   #3
orange66fleet
Lowered in Cleveland
How bad are the mounts, the only bad part on my mounts was the hole, they were about 2in, so I cut out the bad and welded in some new metal with, I think a 3/4in hole. Then again the rest of the mount was ok.
orange66fleet is offline   Reply With Quote
Old 03-16-2009, 10:55 AM   #4
LILRED66
LILRED66's Avatar
An easy repair is to weld a 3" diameter structural washer to the top of the mount, located to line up with the cab mount holes.
Old 03-16-2009, 10:55 AM   #5
rookierodbuilder
The holes are the problem with mine as well, I was just thinking that I may go ahead and put some fresh metal in place since my welding resources are slim. I have a nice lincoln buzz box, but I dont have a 220 outlet that I can use it on (which was very smart come to think of it lol). If it were not for that, I could probably solve my problem by cutting the holes large enough for some huge washers and butt welding them into place.
Old 03-16-2009, 11:39 AM   #6
joe231
joe231's Avatar
it is cheap and easy to run a 220 plug......if you know how
shouldn't cost too much to have it done by a pro...
CHEVY ONLY
Old 03-16-2009, 09:24 PM   #7
LILRED66
LILRED66's Avatar
Most electric ovens and electric dryers have the correct plug, so you can use your welder from these outlets with the correct plug and a pigtail.
Old 03-16-2009, 10:35 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
.....being the electrician in my group of gear-head friends I have made a few 220v extension cord/J-boxes for welder use.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-17-2009, 08:43 AM   #9
rookierodbuilder
come to think of it, I could probably torch the things together, since my torch kit did come with a welding tip. but Im not sure how structural the weld would be.
Thread Tools
Display Modes
