Old 03-16-2009, 10:06 AM   #1
sswitzke
sswitzke's Avatar
Engine noise
I have a tick-tick noise from the engine, it is a stock 305. When it idels it is not there, then when you give it gas it's there. After it warms up it is still there but not as loud. If it is a lifter wouldn't be there all the time? Thanks for the help.
1967 Chevy long bed
1966 Chevy short stepside
sswitzke is offline   Reply With Quote
Old 03-16-2009, 10:14 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Engine noise
im wondering if its not internal to the motor but a loose flexplate or flywheel or is it definately something you can hear from within the motor
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-16-2009, 04:25 PM   #3
73chevyman
73chevyman's Avatar
Re: Engine noise
well depending on the year if your running 87 gas then you could have a spark knock. try the 89 and see if it's still there. thats all it sounds to me but could be wrong. reason i'm saying this is chevy built there motors in the early to late 80ty's for 89 not 87. you can also get octain boost too
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 03-16-2009, 09:30 PM   #4
85Bowtie
85Bowtie's Avatar
Re: Engine noise
I don't think it's spark knock unless you here a sharp "pinging" sound rapidly while under a load.
Sounds to me either you've got a lifter issue or possibly an exhaust leak.
All I've ever run in my '85 was 87 octane and it's always been fine unless I way over advanced the timing.
85Bowtie is offline   Reply With Quote
Old 03-16-2009, 09:42 PM   #5
willett
Another Day, Another Dollar
willett's Avatar
Re: Engine noise
try putting 89 in. see what happens
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 03-17-2009, 01:15 AM   #6
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: Engine noise
tick tick tick tick tick BOOM!
It shouldn't be pre ignition if the engine does it when cold.
Lifters do tend to prime up better after the oil gets hot.
I would check the rockers on both banks, if one is loose, two or three are not
far behind it.
heavychevy79 is offline   Reply With Quote
Old 03-17-2009, 01:26 AM   #7
sswitzke
sswitzke's Avatar
Re: Engine noise
Thank you will try some octain boost, I just filled up the tank.
I was leaning towards exhaust leak, will try some higher octan to see what happens. Then my next day off will look at the exhaust.
will try.
Thank you all for your help.
1967 Chevy long bed
Old 03-17-2009, 01:34 AM   #8
sswitzke
sswitzke's Avatar
Re: Engine noise
far behind it.
That would not be good, but it would give me a reason to rebuild it.
1967 Chevy long bed
Old 03-17-2009, 01:56 AM   #9
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Engine noise
a few years ago my truck was making the ticking when I just put the motor in a found out the passenger side header had pen size hole by the header flange and rocker was a little loose
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-17-2009, 05:19 AM   #10
fast75
Go Hard or Go Home!
fast75's Avatar
Re: Engine noise
i'd check for an exhaust leak, mine does that every time i blow a header gasket. i'd also run your valves, could be something as simple as a loose rocker........good luck.............
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
fast75 is offline   Reply With Quote
Old 03-18-2009, 08:10 PM   #11
73chevyman
73chevyman's Avatar
Re: Engine noise
when i run headers i use the aluminum gaskets they worked great for me
73 C10 Fleetside
Old 03-18-2009, 08:59 PM   #12
factory2wdblazer's
factory2wdblazer's's Avatar
Re: Engine noise
a lifter may need ajusted. or you cound have a worn lifter depending on your engine mileage.
factory2wdblazer's is offline   Reply With Quote
Thread Tools
Display Modes
