Old 03-17-2009, 10:20 AM   #1
Robert8096
Robert8096's Avatar
72 rear drum brake question
A friend gave me a 72 coil spring rear with 3.08 gears. I planning to put it in my 69, I know it is a little wider that my original but my real question is about the opening for adjusting the star wheels. Is the opening suppose to be in the brake backing plate or in the front of the drum? It has a set of drums on it and there is no opening to adjust the star wheels. That is a real pain in the A** when trying to back the shoes off so you can remove the drums.
Robert
Robert8096 is offline   Reply With Quote
Old 03-17-2009, 10:25 AM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: 72 rear drum brake question
there is supposed to be one in the front of the drum, but new drums do not have it. I actually cut a slot in the backing plate so I can adjust (like most rear drums) . I drilled two or three holes, then used a file to clean it up. It looks just like a factory adjusting slot.
When correctly set up, the rear brakes are supposed to be self adjusting.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 03-17-2009, 10:51 AM   #3
Robert8096
Robert8096's Avatar
Thanks. I think I am going to do that also so I can get the drums off that are on it now and if I need to replace them in the future I will not have to worry if the new drums have slots or not.
Old 03-17-2009, 10:58 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Look very carefully at the drums to see if it has a "knockout." If it's stock and has never had this done, you will have to use a hammer and chisel (what I did) to open it.
I had a pic but can't find it. I'll post it if I locate it.
Disregard the info... I reread your post and your access hole should be in the backing plate.
68gmsee is offline   Reply With Quote
Old 03-17-2009, 11:55 AM   #5
Robert8096
Robert8096's Avatar
Originally Posted by 68gmsee View Post
Look very carefully at the drums to see if it has a "knockout." If it's stock and has never had this done, you will have to use a hammer and chisel (what I did) to open it. Disregard the info... I reread your post and your access hole should be in the backing plate
I had a pic but can't find it. I'll post it if I locate it..
I see there is an indention on the drums for the hole and I know that my 69 has the holes in the drums and not the backing plate. I have the backing plates off the 72 rear end, going to powdercoat them so I may just cut the hole there before I coat them and then I don't have to worry whether the hole is in the drums or not.
Old 03-17-2009, 12:30 PM   #6
mr48chev
mr48chev's Avatar
Get a pair of the rubber plugs that normally go in the holes and use them to figure the size of the hole you need and then you can use them to plug the holes.
If everything is working right you shouldn't have to adjust the brakes after you do it the first time but we all know that these often don't seem to work right all the time.
Thread Tools
Display Modes
