Old 03-17-2009, 08:10 PM   #1
stevewhitmore
stevewhitmore's Avatar
Voltmeter Hook Up
In my 69 I have a aftermaket voltmeter that is not hooked up to anything.
Does anyone know what the hook up is. I assume a wire goes from the meter to somehwere. It has HEI ignition to a 307 motor
Apprviate any help here
69 Shortbed 307 with 350 trans
stevewhitmore is offline   Reply With Quote
Old 03-17-2009, 08:15 PM   #2
72BLUZ
72BLUZ's Avatar
Re: Voltmeter Hook Up
it should have a wire that goes to the ignition side that will read votes when the switch is on. and a positive and ground for the light.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 03-17-2009, 10:49 PM   #3
Andy4639
Old member
Andy4639's Avatar
Run a + wire to key on, and ground.
The terminals should be marked + & - on the gauge.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-17-2009, 11:23 PM   #4
spinning wheels
spinning wheels's Avatar
Must be a politician's meter?
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-18-2009, 05:56 AM   #5
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
"Votes"
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 03-18-2009, 12:14 PM   #6
stevewhitmore
Unhappy Re: Voltmeter Hook Up
On the back of the meter there are 3 studs with nuts on them.
No markings of + or - anywhere. There is a light bulb socket top center.
The studs on the left and right appear to be just for the bracket holding the meter into the chrome housing, but not sure
Stll stumped on this one.
Old 03-18-2009, 12:28 PM   #7
Grip
Grip's Avatar
Pics?
Grip is offline   Reply With Quote
Old 03-21-2009, 07:05 PM   #8
stevewhitmore
Well I went to the local auto zone and looked at a new one and found that one wire goes to ground and one to the fuse panel
Thread Tools
Display Modes
