Old 03-17-2009, 08:50 PM   #1
LEEVON
Moderator
LEEVON's Avatar
'87 305 TBI won't start
I pulled this motor to seal up some leaks. It is a 305 TBI in an '87 silverado, factory stock, no modifications whatsoever. I put everything back like it was and now it cranks but won't start. All I was able to check was voltage at the fuse block to verify that all ignition and fuel related circuits are getting power.
I also poured a little fuel on the throttle blades just to see if maybe I had spark and no fuel with no luck. Where should I start troubleshooting?
Thanks!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-17-2009, 10:18 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: '87 305 TBI won't start
Sounds like something is not plugged in. Have someone crank it while you look at the injectors and see if there spraying. If not then no fuel. check pump circuit. If yes then pull a plug wire and see if you have spark. If not check Distributor. Coil and distributer is all plugged in?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-17-2009, 10:40 PM   #3
LEEVON
Moderator
LEEVON's Avatar
well I had the wife crank it while I looked at the injectors, plenty of fuel. Coil is suspect now. It has all new plug wires, cap, rotor, etc...something must not be making contact at a connector to the coil.
Old 03-17-2009, 11:17 PM   #4
kelsfine69
18 Till I Die
kelsfine69's Avatar
It might be the module in the Dist?
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 03-18-2009, 10:14 PM   #5
LEEVON
Moderator
LEEVON's Avatar
Yes that is surely suspect. I guess parts stores can test those modules, I'll have that done.
I checked resistance on the coil wire and all the fuses. Also unplugged and re-plugged all the connectors. Next step is to check resistance on the coil and continuity on the wires from distributor to ECM.
Does this sound like the right course to everybody?
Old 03-19-2009, 12:39 AM   #6
rfmaster
rfmaster's Avatar
Unlikely, if EST module failed ECM would not receive DRP pulses from distributor. Without DRP pulses from dizzy ECM would never fire injectors.
I would check ignition coil and wiring. External coils are prone to fail unlike earlier in HEI (large diameter HEI).
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 03-19-2009, 09:14 AM   #7
jchav62
1962 C-10
jchav62's Avatar
I agree. Sounds like something didn't get plugged in or is loose. Recheck all connectors.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-19-2009, 08:02 PM   #8
chevymotocross
chevymotocross's Avatar
I had a similar problem and it was my pickup coil. Don't remember if I was getting fuel from the injectors like you are though. Odd that it started fine though before you pulled the engine.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 10-19-2009, 09:13 PM   #9
turbo350
Leevon, did you ever figure out what the issue was?
turbo350 is offline   Reply With Quote
Thread Tools
Display Modes
