Old 03-18-2009, 09:50 AM   #1
yellowGT
yellowGT's Avatar
wiring harness help
went out to start my truck (69)and it wouldnt start. It turned over the first time but then nothing after that. I got under the dash and the harness looked like the wires melted together so obviously something is shorting out. I think. I yanked that harness out and replaced it with a harness that came out of my 68 and same thing. I have power to the hei, nothing at the fuse block. Will the safety switch have to be plugged in? What can you tell me about the wire colors that run to the ignition? I do remember the capacitor or whatever that thing is on the core support was not plugged in before when truck started so I dont think thats the issue. What can you guys make out of this problem? Would i need a harness out of a 69?
Much help appreciated.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 03-18-2009, 11:15 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: wiring harness help
I am not sure on this, BUT try this thread...it is a colored wiring diagram
http://67-72chevytrucks.com/vboard/s...d.php?t=185665
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-18-2009, 12:27 PM   #3
yellowGT
yellowGT's Avatar
I show power at the batt terminals if clipped directly but then ground to the frame or other spots and touch the pos. side of batt and it powers up on and off. Hei has power. No horn no turn signals or lights. Its a big mess
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 03-18-2009, 01:42 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I wouldn't mess around with the old wires. Sounds like you are lucky that a fire didn't start up. You have a dead short somewhere. It could be the purple starter wire is shorted against the motor somehow. I am having to completely rewire a 72 Blazer here because the owner tried to patch the wiring together and it wouldn't start, nor would the brake lights and right rear turn signal work. Replace the wiring with new and save yourself the headaches of trying to chase wiring gremlins around. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-18-2009, 03:57 PM   #5
Kayotic
Kayotic's Avatar
I hate trying to trouble shoot wiring with words but,
Do you have the second wire off the positive side that goes to the little junction on the passenger fender?
My truck wont start unless it's connected but causes the poss. battery terminal to get hot.
Also check the jumper connection on the starter, mine has two copper leads comming from the selonoid, make sure that is good and tight...
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 03-18-2009, 10:10 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by yellowGT View Post
Will the safety switch have to be plugged in? Much help appreciated.
Everyone seemed to miss this part. Yes, the neutral safety switch will have to be plugged in or a jumper wire connecting the Purple wires at the plug... Just remember if you do that it will start in gear. Don't run it through the back of the garage...
LockDoc
Leon
Old 03-18-2009, 10:49 PM   #7
yellowGT
yellowGT's Avatar
Thank you to the guys who responded. I got to messing with the truck again today after i got home from work and finally figured the problem out. I got to say I couldnt of done it without my expertise.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 03-19-2009, 07:45 PM   #8
El Jay
Gone to greener pastures
What was the problem?
Inquiring minds want to know.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Thread Tools
Display Modes
