![]() Join Date: Nov 2006
rear disc rotor question (camaro claipers )
could soomebody tell me what rotor is used when you do the camaro rear disc brake swap ? i plan on also using the parking brake on the calipers. just want to know exactly what all is involved before i make the jump.
thanks bob
I BELIEVE IN JOHN 3:16 |
Never Ending Projects
Re: rear disc rotor question (camaro claipers )
'94-'96 Impala SS (or equivalent other GM car) rotors. You will need to machine the "lip" off the axle flange, where the drum normally rides on or you won't get the rotor to sit flush. I pulled the axles and has it done locally for $20. You could open the hole slightly on the rotors but then if you ever have to replace them, you would have to remember to do that again. By doing the axles, you can just swap new rotors on whenever you need them.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
do you use the rear rotors off the impala ?
thanks mike
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 03-20-2009 at 12:49 PM. |
vw guy & now c-10 guy
![]() Join Date: Sep 2008
not trying to hijack, but is there a rotor you can use and keep the 6-lug set-up? thanks.
#5 | |
There are a bunch of outfits making brackets to mount rear disks on trucks. Usually using the 4x4 front calipers or using 76/78 Cad Eldorado calipers with the park brake. My son pulled the front rotors off his 2000 GMC 4x and outside of the bolt holes being larger I think they have possibilities on a six lug setup. 12 inch rotors though. |
Sorry, yes, rear rotors.
I got mine from Rock Auto, http://www.rockauto.com/catalog/x,ca...,parttype,1896 the ones tha are $27.79 each (same for both sides). These are Raybesto ones.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... Last edited by chevy_mike; 03-20-2009 at 03:38 PM. |
thanks a bunch guy,s maybe i can help you out someday.
bob
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 03-21-2009 at 02:03 PM. |
Thread Tools | |
Display Modes | |
