Old 03-21-2009, 02:06 PM   #1
biggreen292
2wd to 4wd?
how much of a disaster project is putting 4wd into my truck? are they even the same frame? guy has the trans, t case, axles, springs, and wheels not sure on driveshafts but probably. his is a 3/4 long bed too. i really just need a rear spring pack(is that the same 2wd to 4wd?) but if i can make it 4 wheel then hey why not.
http://i16.photobucket.com/albums/b3...fleet041-1.jpg
71 custom camper/20:292/saginaw, my first pickup
83 cutlass cruiser:307/th250c, lifelong project
96 caprice 9C1:LT1/4L60E, police package
83 buick regal estate: buick 350/m20
69 bel air:250/m21
biggreen292 is offline   Reply With Quote
Old 03-21-2009, 02:22 PM   #2
dan42
dan42's Avatar
Re: 2wd to 4wd?
There was a thread on this a while back and if I recall the verdict was find a 4WD frame, otherwise it's too much of a PITA.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-21-2009, 02:59 PM   #3
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: 2wd to 4wd?
Sounds like an abortion to me, You'll be making custom cross-members, depending on your skill level, it maybe better to just find a new frame or a rolling chassis, plus you can do a frame up build :P would love to see it. 2 wheel drive and 4wd use different rear springs, i believe 4 vs 5 spring, possibly different lengths but I honestly dont know.
Eturnit3 is offline   Reply With Quote
Old 03-21-2009, 04:44 PM   #4
biggreen292
Re: 2wd to 4wd?
mines a 6 spring rear, probably due to the custom camper package. LMC and such dont list 2wd rear leaf springs, just 4wd. i keep meaning to call my local spring shop, i'm sure they can make a spring for it but i'm trying to go as cheap as possible to get it inspectable. screw the 4wd for now, i dont need another big project just want my pickemup back on the road, i have junk to haul!
69 bel air:250/m21
Old 03-21-2009, 08:16 PM   #5
onlyifihadachevy
Re: 2wd to 4wd?
from my build it was easy just drilled 4 holes for the t case and everything swapped easy but i have a custom camper
o, leafs are the same well i used the same axle for the back
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 03-21-2009, 09:17 PM   #6
FormerMember
Re: 2wd to 4wd?
Sounds like people haven't converted a 2wd frame to 4wd.
I have. I'd say it's easier than a body swap.
Check my sig.
FormerMember is offline   Reply With Quote
Old 03-21-2009, 09:58 PM   #7
onlyifihadachevy
Re: 2wd to 4wd?
i know body swaps can be hard lining it up with the frame front clip and the bed
My 72 thread
Old 03-22-2009, 12:21 PM   #8
biggreen292
Re: 2wd to 4wd?
i talked to the guy a bit today, its a rolling chassis for $500 so i'll probably get it sometime next month, need to get rid of some stuff first. i guess someone used the cab and bed on a 1/2 ton project, not sure how long the frame has sat around but i'll check it out next weekend most likely.
69 bel air:250/m21
Old 04-29-2009, 06:13 AM   #9
badaceissimo
badaceissimo's Avatar
Re: 2wd to 4wd?
Check my sig.
You'll have to let me know about this then. I was hoping to do this on my c10 truck but I kinda don't want to go through the hassle of new frame or truck. I really just wanted to beef up what I have. My biggest dilemma I think is finding a way to setup the front suspensions and steering. I don't know where to get or how to make one of these happen. I hope this much bolts right on. This assuming that the four holes needed are for the transfer case only. Would I need a new drive shaft as well? Someone feel free to let me know. badassissimo@gmail.com
badaceissimo is offline   Reply With Quote
Thread Tools
Display Modes
