Old 03-21-2009, 08:34 PM   #1
JW76
JW76's Avatar
axle center section swap
I have a 1969 rear end with a 3.73 posi setup and 6 lug. I also have a 1980 axle with an open diff. 2.76 and 5 lug. They are both 12 bolt axles. I would like to use the correct axle for my truck.... the 1980. Is there a way to take the gears and center section out of the 69 and install it in the 80? Thanks for any help.
JW76 is offline   Reply With Quote
Old 03-21-2009, 08:47 PM   #2
Blue85
Oilfield Trash
Blue85's Avatar
Re: axle center section swap
I'll let someone else give you the for sure it will work answer, but I am 99% positive that you should be able swap the carrier, ring and pinion to the 1980 axle.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 03-22-2009, 09:17 AM   #3
LONGHAIR
Swapping gears is a job that is best left to a professional. It is a very exacting and tedious process....but getting someone to swap "used" gears is nearly impossible.
If the 3.73 housing is in good shape and the posi unit is good, it may be more cost effective to get yourself some 5 lug axles for it. Then swap entire housings. You can do all of the work on the housing while it is out of the truck, which makes for a quick swap.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Thread Tools
Display Modes
