Old 03-22-2009, 04:29 PM   #1
mongoose
mongoose's Avatar
lowering + drop?
hey guys, probably a simple question... but, anything to say away from when dropping and giving the truck a decent amount of power?
should be around 500+hp, and I was going to do a flip kit in the back... just wondering if it's a good choice?... not really worried about hooking, more or less just wheel hop in crap like that.. thanks.
mongoose is offline   Reply With Quote
Old 03-22-2009, 06:41 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: lowering + drop?
It wheel hope like crazy you'll need traction bars or http://store.73-87chevytrucks.com/me..._Code=7387SUSP
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-22-2009, 07:09 PM   #3
Primer70
Superbad
Primer70's Avatar
I know traction bars will help with wheel hop, but mounting the springs under the axle should make wheel hop less than with the springs over the axle.
Primer70 is offline   Reply With Quote
Old 03-22-2009, 08:16 PM   #4
mongoose
mongoose's Avatar
do those work better than normal bars? they look pretty easy to make...
Old 03-23-2009, 11:52 AM   #5
Primer70
Superbad
Primer70's Avatar
You will loose some suspension travel with the traction bars that mount to the u-bolt spring plate & frame, because they will cause the suspension to bind up some. The ones that just have the rubber bumpers that ride against the bottom of the leaf springs might allow the axle to wrap up some, but the ones that mount to the frame will stop axle wrap for sure. I'd run the ones that mount to the u-bolt spring plate & frame.
Old 03-23-2009, 11:46 PM   #6
mongoose
mongoose's Avatar
cool man.. thanks for the input, pretty much building it to drive to timmies, and do burnouts... so great suspension travel/geo isn't the much a a concern.
Thread Tools
Display Modes
