Old 03-23-2009, 11:00 AM   #1
smoky02
Location: Sunny, Florida, some might call it South Alabama
67 Crossmember
Hey ya'll,
My dad and I installed a 283 w/ a 3 O/D manual a few days ago. Everything went great until we got to the crossmember. We tried to slide it in place, (came out of a 71) and it wouldn't fit. When we held it up under the frame, it is actually longer than the frame is wide. Has anyone else run into this problem and if so, how did you correct it?
Thanks in advance,
Brandon
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 03-23-2009, 03:03 PM   #2
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: 67 Crossmember
My 67 has the same issue with the original crossmember. I didn't think it was right, but it is. Install them the same way you get them out......with a BFH. It is a tight fit, but it will push the frame out and then it will settle against the frame flush once you get it in. You have to use some persuasion but it will fit! My cab and bed were off when I took mine out so that may have helped some with the frames ability to open wider.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 03-23-2009, 03:04 PM   #3
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: 67 Crossmember
Originally Posted by smoky02 View Post
Hey ya'll,
Thanks in advance,
Brandon
I have a 67 man crossmember
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-23-2009, 04:49 PM   #4
smoky02
Re: 67 Crossmember
Would you post a picture of it up on here please?
Old 03-24-2009, 09:57 AM   #5
smoky02
Re: 67 Crossmember
Also would you please measure the length of the cross member as well.
Old 03-25-2009, 10:01 AM   #6
smoky02
Re: 67 Crossmember
Ttt
Thread Tools
Display Modes
