clutch worked ok last year. now started out slipping some, and the more i used it, the worse it got. now won't even move. mice got in it last winter. i was told that if they fill the clutch up with nesting stuff, it will get in the fingers and prevent the clutch from engaging.
so, is there a easy way to get at the clutch? what do i need to do, and how do i do it? thanks
1949 chevy 3100, 5 window 1992 chevy k1500, extended cab, short box 5.7l 1996 chevy k1500, extended cab, long box 5.7l 2001 chevy impala ls 3.8l 1965 honda s90 |
Cantankerous Geezer
Re: 1949 3100. clutch issues - mice?
You can remove the cover plate on the bottom to inspect. I've never heard of mouse nests causing a problem there. The only way to inspect the throwout bearing is to pull the tranny. Not an easy job. The reprint of the shop manual does a good job of describing this.
Go to http://chevy.oldcarmanualproject.com/ and scroll down to the 48-51 truck shop manual. Clutch removal starts on page 6-88. Tranny removal is page 7-4.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
i say burn them out get the clutch hot by slipping it and if there's anything in there it should turn to ashes. most likely your rear main seal is leaking or your clutch has had enough
good luck GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
Cantankerous Geezer
One other possibility is the pullback (retracting) spring. If it is broken or unhooked the clutch will not remain engaged. Usually starts slipping at speed or under load. The clutch will still be toast, but then you know why.
Thread Tools | |
Display Modes | |
