Old 03-25-2009, 11:58 PM   #1
MN Rooky
1971 4X4
MN Rooky's Avatar
Who's Running Rear Disc Brakes???
Just found out that my drums are shot on my Eaton rear end. The drums will run me about $220 each plus shipping. I've been told that I could change them over to disc brakes for less. I have a salvage yard pretty close so I can hunt down parts.
What's your thoughts on the disc brake conversions?
Is it a better way to go or not?
MN ROOKY
1971 Chevy 3/4 4X4, 4" lift, 33's
2001 Chevy 3/4 4X4 HD, 33's (Wife's Truck)
MN Rooky is offline   Reply With Quote
Old 03-26-2009, 09:46 AM   #2
Burt4x4
Burt4x4's Avatar
Re: Who's Running Rear Disc Brakes???
I do but I have a 14bolt rearend.
You need a diskbrake conversion mounting bracket to mount the calipers too...not sure if anyone makes one for Eaton rear..google it
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-26-2009, 12:07 PM   #3
Mudder
Mudder's Avatar
I have disks on my 14 bolt but I don't have Ebrake. It's a good cheap way of going to disk using all the stuff from a dana 44. There is a way of doing the ebrake using a line locks but I have never done it.
Mudder is offline   Reply With Quote
Old 03-26-2009, 03:44 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Originally Posted by Burt4x4 View Post
..google it
I Googled eaton disc brake conversion and got this... http://67-72chevytrucks.com/vboard/s...d.php?t=316102
and this:https://www.4wdfactory.com/store/pro...7D-Eaton).html
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 03-26-2009, 03:48 PM   #5
Burt4x4
Burt4x4's Avatar
Originally Posted by Stocker View Post
heheheh ya not to many people modifying that old axle, cheeper to just swap in a 14FF and be done
Old 03-26-2009, 10:49 PM   #6
MN Rooky
1971 4X4
MN Rooky's Avatar
Thanks for the information. I was just looking into swapping the axles. Is the only certain years that will be a direct swap without moving anything?
MN ROOKY
Old 03-27-2009, 09:10 AM   #7
msgross
msgross's Avatar
find the cheapest (best shape with correct gears) axle and weld your own perches on if they aren't correct.
there are some board vendors selling rear disc kits and
www.diy4x4.com has tons of cheap brackets for you...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-27-2009, 09:18 AM   #8
FormerMember
I have disks on all my rigs.
a 1ton 14B is a bolt into our trucks, they use the same pad spacing. They're also likely to have 4.10 gears and some had detroits.
the CUCV axles are a 1 ton variant that will bolt in as well.
Then you're onto to the disk brakes.
BTW, a line locker on your existing brake system is not a street legal emergency brake. It needs to be separate from your normal braking system.
I run driveline e-brakes.
FormerMember is offline   Reply With Quote
Old 03-28-2009, 01:29 AM   #9
woodwright
Enjoying left field
woodwright's Avatar
Do you have any pics of that? Most reear disk setups that i've seen were alot more money with a paking brake built in.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 03-28-2009, 06:38 AM   #10
mothertrucker424
mothertrucker424's Avatar
i am currently swaping my eaton with rear disc brakes from ruff stuff specialties will be making a build page soon i got alot of pics if you need any
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 03-28-2009, 07:51 AM   #11
FormerMember
http://highangledriveline.com/e_brake.html
Old 03-28-2009, 08:15 AM   #12
Mudder
Mudder's Avatar
man that is a sweet set up. May just have to look into that. Missouri doesn't check for Ebrakes so I have been without since I went with the rear diskes.
Old 03-28-2009, 08:44 AM   #13
FormerMember
That's an advantage.
NH does check, so I have that on my Jeeps, (14B rear with disks) (x2 Jeeps).
I went with Caddy calipers on the C/K conversion from Blackbirds.
Old 03-28-2009, 11:20 PM   #14
MN Rooky
1971 4X4
MN Rooky's Avatar
I went with the 14 BFF. I found one for $100 on craigslist. It looks to be in good shape. I'll post pics tomorrow.
MN ROOKY
Old 03-29-2009, 08:23 AM   #15
FormerMember
Driveline ebrake
Here's the set up on one of my Jeeps:
Old 03-31-2009, 01:13 PM   #16
earl87gta
earl87gta's Avatar
I love my eaton way to much to get rid of it and its the same price to convert a 14blt as an eaton so no reason to change it out. I think I have less then 100 in the disk convertion.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 03-31-2009, 06:12 PM   #17
ybnaford
Junior Member
ybnaford's Avatar
I bought my brake conversion kit from this gentleman for my Eaton H072. Below is his info but you might want to call him first. After payment got my parts the following Friday for $315.00 included shipping from TN.
Paypal to gubniatcomcastdotnet and include the year and type of axle you need the kit for. You can also call me if you want 423-737-0265
Shawn Miller.
Good Luck with your build.
ybnaford is offline   Reply With Quote
Old 03-31-2009, 06:26 PM   #18
ybnaford
Junior Member
ybnaford's Avatar
This is my Eaton H072 with the Disc Brakes.
Name:  Eaton Rear 4.jpg
Old 04-03-2009, 06:38 AM   #19
mothertrucker424
are calipers supose to be to front or rear of axle?
Old 04-06-2009, 07:51 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
As previously mentioned check with our forum vendors. Here is an April special just posted for Blackbirds- LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-06-2009, 09:59 AM   #21
drink2mny
drink2mny's Avatar
Yup.. A month long deal... Free shipping to the lower 48 states..
Support The Board
drink2mny is offline   Reply With Quote
Old 04-06-2009, 03:09 PM   #22
BIG HEAD
If you get two front rotors and calipers for a mid 80's 3/4 ton 4x4 from the local parts house you can make your own mounting bracket with a torch, drill, & grinder. Get your calipers loaded. that means they come with pads, clips, bolts, ect. Or you can find the mounting brackets new on ebay.
MY POND TRUCK BUILD http://www.67-72chevytrucks.com/vboa...d.php?t=297393
BIG HEAD is offline   Reply With Quote
Old 04-07-2009, 05:29 PM   #23
ybnaford
Junior Member
ybnaford's Avatar
Replying to the question in the Front or the Rear? If for everyday driving as viewed on just about every vehicle, the calipers are in front. If you are doing alot of offroading, with hardly any road time then in the rear would be preferable. That way as to not damage the calipers on any rocks or objects. Hope this helps. Mine are in the front since this will be a more road vehicle with maybe a little mud and crud now and then.
Old 04-09-2009, 08:53 PM   #24
mothertrucker424
Originally Posted by ybnaford View Post
Replying to the question in the Front or the Rear? Hope this helps. Mine are in the front since this will be a more road vehicle with maybe a little mud and crud now and then.
yep thanks
Thread Tools
Display Modes
