Old 12-20-2002, 02:18 AM   #1
crackajacka
Stylin
crackajacka's Avatar
aframe shaft question
i ordered a aframe shaftn when i got it its offset from the ones that i need. the part number came out of the gm book. there was only one part number for it so it couldnt of gotten screwed up heres a pic of what im talkin about. what should i do if i can use it i would like to go ahead n do that, but if i should send it back i will. thanks paul
the pic of what im talkin about is here
crackajacka is offline   Reply With Quote
Old 12-24-2002, 01:04 PM   #2
68LSS1
68LSS1's Avatar
If the new one fits the bushings then it will probably work. Being offset like that you'll need to get it aligned (the front end) as that would surely throw the camber off.
68LSS1 is offline   Reply With Quote
Old 12-24-2002, 10:03 PM   #3
BIGG BELLY
that shaft is designed to give you a little more camber adjustment it should work the same as the original--make sure you rotate the shaft to give you proper camber gain
55 big window long bed
69 olds 98
check out my pics
photo albums
BIGG BELLY is offline   Reply With Quote
Thread Tools
Display Modes
