Old 03-26-2009, 11:58 AM   #1
DANTIP
DANTIP's Avatar
Steel Wheel Painting?????
I had a local paint shop mix one pint of paint code 521 (1972 white) for my steel wheels and they put it in spray bombs for me.
The wheels I have are very clean with original paint but have enough scratches to warrant paint. Do I try to paint the wheels before having tires mounted then touch-up after mounting?
I have seen other people do a great job of wheel painting with the tires mounted but I think painted balancing weights would look silly. I want a very original look with as little hassle as possible.
Any thoughts?
DANTIP is offline   Reply With Quote
Old 03-26-2009, 12:01 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Steel Wheel Painting?????
In my opinion, have them soda-blasted, then paint them. Balancing would be done after the tires are mounted. I have done it other ways, but this would look better.
Member Nr. 2770
Old 03-26-2009, 12:04 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Have them balanced on the inside so you don't see the weights.
leddzepp is offline   Reply With Quote
Old 03-26-2009, 05:24 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
You can also mark the tire where the weights are, remove them, mask of the tires, paint the wheels (after cleaning and scuffing) and then put your weights back where they were.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-26-2009, 06:17 PM   #5
john02fxdl
This is what I recently did. I sandblasted my steel wheels first, mounted my new tires second, but don't fill them with air OR bead them to the wheel. Mask off the tire, paint the wheel (front and back). Let it dry, install valve stem, blow up the tire(make sure the beads seat) and balance. If you do it in that order, the wheel won't get scratched. There are two types of balancing methods for wheels, static and dynamic. Static is weights on inside only, dynamic is on both, your choice.
When I grow up, I want to be the man my wife married.
I used to be schitzophrenic, but we're O.K. now
john02fxdl is offline   Reply With Quote
Old 03-26-2009, 11:26 PM   #6
You can have your wheels powder balanced.I paint mounted wheels using 4" strip of metal I wrap arond the edge of the wheel.Works great! You can always paint the weights bak to silver grey.
Old 03-27-2009, 02:46 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Good thread...lots of great ideas here.
Old 03-27-2009, 04:03 AM   #8
4x4toy
I like this stuff, Have it in my 2005 GMC tires. Internal tire ballancer. No more ugly weights.
http://www.innovativebalancing.com/
I have also used this stuff too.
http://www.imiproducts.com/equal/tire-balancer.aspx
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 03-27-2009, 08:06 AM   #9
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I have done both but the way of choice would be to paint your wheels first then have the tires mounted, the new machines don't even touch the rim think about the guys buying rims that cost $1000 each, then static balance them (weight on in side of wheel you could even use the sticky ones and hide them behind the centers) that should get you what you want and most tire shops could do it
On a side note I have found that rustolium industrial spray bombs hold up great but only come in basic colors. Just give them plenty of time to dry before you mount them.
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-27-2009, 02:05 PM   #10
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: Steel Wheel Painting?????
I say blast them and powder coat them white..
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 03-27-2009, 02:27 PM   #11
SacramentoJoe
Always Fixing Things
SacramentoJoe's Avatar
That is what I did. I recently had the tires rebalanced and need to do some touch up.
Just an Average Joe
‘68 GMC 307 3spd – My dad's original truck
310,000 miles
SacramentoJoe is offline   Reply With Quote
Old 03-27-2009, 02:44 PM   #12
my67chevytruck
Under Construction
my67chevytruck's Avatar
Any thoughts?
with the technology these days, the tire tool never really touches the rim. I think i would clean or blast them , then paint them. give me 3-4 days or so to make sure paint is fully cured. I would then have the tires mounted (talk to a manager and alert them of your concerns so a New tech doesnt do this), and balance them dynamically (weight on inside only). if the installer is cautious , you shouldnt have any issues.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Thread Tools
Display Modes
