Old 03-26-2009, 11:01 PM   #1
caja_larga
jumpy speedo..
I just installed a neew speedometer from Brother trucks. The speedometer needle jumps around (5mph +or-) I have a new cable in it already and I tried to lube the cable. It this common for the replacement speedos?
caja_larga is offline   Reply With Quote
Old 03-26-2009, 11:10 PM   #2
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: jumpy speedo..
Mine does this when it's really cold out..
texanidiot25 is offline   Reply With Quote
Old 03-26-2009, 11:17 PM   #3
tim21391
tim21391's Avatar
Re: jumpy speedo..
x2
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-27-2009, 10:01 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: jumpy speedo..
A dirty cable is usually the culprit.
Did you replace the whole cable or just the inner?May have gunk build up on the inside that needs to be cleaned.
Is the new cable binding, (cut a corner to sharp) something causing stress on the inner cable.
sneakysnake is offline   Reply With Quote
Old 03-27-2009, 11:00 AM   #5
shawn57nomad
shawn57nomad's Avatar
Re: jumpy speedo..
how long is the cable for a 350 with a 400 auto? just wondering. my speedo jumps because the cable that's on it now is from the original 3 speed column and it is real tight.
FAST cars don't make power to the front wheels, THEY LIFT 'EM!
shawn57nomad is offline   Reply With Quote
Old 03-27-2009, 11:51 AM   #6
cdowns
cdowns's Avatar
Re: jumpy speedo..
what did you try and lube the cable with?
they make a special speedo cable lube that is graphite based and it lubes and also polishes the inside of the cable housing for smooth operation/// using heavy grease white grease and similar will dry out and cake up causing drag and a jumpy needle
Thread Tools
Display Modes
