03-27-2009, 06:59 AM | #1 |
Original ride height?
Does anyone know the measurement from the center of the axel to the top of the wheel arch? I've seen measurements of 32"/front & 34"/ back as measured to the ground, but that is assuming stock wheels and tires.
'69 short step with dreams of being a hot rod You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. |
03-27-2009, 10:23 AM | #2 |
WTB this ad
Re: Original ride height?
Early Classic claims their 6" drop rear coil will leave 3" between the frame and axle tube. From that statement I assume that a new stock height coil would be in the area of 9" between the frame and axle tube. No idea what the front would be.
You're on the right path checking from the center of the wheel to the fender lip. That's the only way to get a good mesurement that disallows tire size variances. |
03-27-2009, 11:02 AM | #3 |
Thanks SEE TEN....that's a starting point.
03-27-2009, 11:58 AM | #4 |
I actually did this a couple months ago and wrote it all down.
For the front I have ~31-3/4" up front from the ground to the wheel lip and ~18-1/2" from the center of the wheel to the fender lip. For the rear I have ~33-7/8" and ~19-3/4" respectively. They varied a little from side to side so I took the average of the two front and two rear measurements to get what I posted.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 03-27-2009 at 12:01 PM. |
03-27-2009, 12:28 PM | #5 |
Thanks Jesse, that was what I needed.
03-27-2009, 03:28 PM | #6 |
whats the hight of the original tires though?
Thread Tools | |
Display Modes | |
