03-31-2009, 01:12 PM | #1 |
72 blazer headers
I have a 72 k5 blazer with SBC, sm465, np205. I am having trouble with the Hedman headers that are on it. I hate the way they interfere with the clutch rod.I was wondering If any of you fine folks have had better luck with a different header. I am running the 2.5 inch exhaust to 40 series Flowmasters with turn downs. I do wheel this rig so ground clearance. I do have a welder and a apt. at fab work.
duct tape+bailing wire = trail fix if it aint broke it will be whoa hillbilly |
03-31-2009, 01:17 PM | #2 |
Re: 72 blazer headers
what is the headers clearance , if any
03-31-2009, 01:19 PM | #3 |
:metal
03-31-2009, 02:09 PM | #4 |
were should I messure for that?
03-31-2009, 02:21 PM | #5 |
I use to run the same setup.
Here you can seet he hedmen Elites and my clutch mounting point on the frame. Look close at that mount and you will see I moved the mount hole towards the firewall. Simply drilled a hole in the bracket. The Z-bar will still work fine even if it is at a slight angle to clear the heder tube.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
Thread Tools | |
Display Modes | |
